2012 Prius V Errors after car wash
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by John Traynor, Jul 30, 2024.
  1. John Traynor
    John Traynor Junior Member
    23
    While I am no stranger to unfortunate coincidence, I am hoping this is one. I went through. A car wash with car in neutral and engine running.
    the car gave me a “your car is rolling in neutral idiot, put it in park.” Then the car went into power off/ accessory made with a power steering error light on the dashboard.
    I coasted out, restated the car and pulled into a parking space. I turned off the car, waited a minute and restarted.
    The power steering light was gone but now I had both ABS lights, the check engine, and the hybrid error. I used my Veepeak OBD2 and Car Scanner.
    Car Scanner ELM OBD2
    DTC report
    Selected brand: Toyota
    VIN: ************
    ============1==============
    P0A80
    Raw code: 0A80
    ECU: 7EA
    Status: Confirmed
    Hybrid battery pack Deterioration
    ============2==============
    P3000
    Raw code: 3000
    ECU: 7EA
    Status: Confirmed
    High Voltage Battery Fault; HV Battery Malfunction
    ============3==============
    C1259
    Raw code: 5259
    ECU: ABS control unit #2
    Status: Confirmed
    ============4==============
    C1310
    Raw code: 5310
    Status: Confirmed
    ============5==============
    P0A80
    Raw code: 0A80
    ECU: Hybrid engine system
    Status: Confirmed
    ============6==============
    P3000
    Raw code: 3000
    Status: Confirmed
    I drove it a few miles, parked and I am still getting the hybrid and check engine lights. I haven’t tried resetting them yet.
    Did I get water in the computer or sensors?
    EDIT 1: ABS error lights went off, error codes went away.
    EDIT 2: I manually reset the hybrid errors and drove 20 miles. They have not returned yet. I’m thinking I have a loose harness that got sprayed.
    #1 John Traynor, Jul 30, 2024
  2. John Traynor
    23
    Deleted
    #2 John Traynor, Jul 30, 2024
  3. ChapmanF
    18,896
    The codes that weren't P0A80 were all because of the P0A80.
    The P0A80 indicates that the traction battery didn't hold its balance well while it deep-discharged in neutral in the car wash. Those are conditions very much like the actual "confirmation driving pattern" that's in the repair manual for the P0A80 code: to confirm that the battery is healthy, one part of the pattern is where you shift to neutral and let the ECU see how well it stays balanced in a deep discharge.
    Yours did not pass with flying colors, but since then it has passed a few of the car's self-tests, enough for the current code and light to go away. We could infer that your battery may be a bit long in the tooth, but for now it's saying it's not dead and doesn't want to go on the cart.
    The P3000 was a more-generic hybrid-system-problem code set by the same ECU, because of the P0A80, and the C1259 and C1310 were codes that are set in the brake ECU when it is notified of a hybrid-system problem.
    John Traynor likes this.
  4. John Traynor
    23
    Holy frijoles Batman. You just spilled a whole can of beans on me. I had AC on full blast because it’s hot and I was draining the battery.
    Time to get the battery longevity app from Dr Prius.
  5. bisco
    52,703
    don't use car washes that require neutral
  6. ChapmanF
    18,896
    Or, enter them with the battery at a high state of charge, and forgo air conditioning for those couple minutes.
    Brian1954 likes this.
