2012 Prius V grinding from drivers front
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Bfoster, Sep 18, 2017.
  1. Bfoster
    Bfoster Junior Member
    Loiuville
    2012 priusV. 65k miles. The noise is present when transitioning from ev mode to ICE. I've replaced plugs drivers side axle , trans fluid, cleaned egr tube and intake manifold. Dealer says new trans is needed for 6,400.00 Cost me 400 just to tell me that. No slipping or codes. I will try to upload a video clip
  2. Bfoster
    Loiuville
  3. Prodigyplace
    Prodigyplace Senior Member
    11,701
    11,321
    Central Virginia
    Did the dealer give any diagnostic codes to support their hypothesis?
  4. Bfoster
    Loiuville
    No codes or CEL.
  5. Mendel Leisk
    38,952
    The warranty is what, 5 year? Any chance of goodwill from Toyo? that's very low miles.
  6. Bfoster
    Loiuville
    There is no warranty left. I think Toyota really doesn't want to deal with repairs so they overprice jobs to the point it's really comical They make their money on changing oil and power streeting fluid. I'm just gonna drive it till something breaks. Then I will know what to fix. ??
  7. Air_Boss
    Air_Boss Senior Member
    4,001
    1,093
    New Yawk
    Were this a manual transmission, I would say it was a separated and flailing clutch surface.
    As it is, appears to be from the CVT, which overruns under load. A solenoid/clutch pack, perhaps.
    Does the sound continue at speed, or go away?
  8. Bfoster
    Loiuville
    It goes away at a higher rpm but as you reach the speed you want and ease off the accelerator it begins the grinding noise. Only while the ICE is running. It runs smooth at idle
  9. Air_Boss
    4,001
    1,093
    New Yawk
    If so, it appears to be in the CVT overrunning clutch. Might find a removing original and installing a replacement unit to be thousands less expensive than what dealer quoted.
  10. TheToolMan
    TheToolMan New Member
    23
    Wait. Small world. You had this car for sale on Craigslist and told me via text that the repair would be, "500-1500 worse case scenario". And you sent me pics of an old Carfax that didn't show any of the repairs that had been done when your report was pulled, but I found them when I pulled it myself.
    When I asked you about the airbag light that was on in your photo you said, "It goes off after a few seconds." But when I pulled the service records, I found "MISC.REPAIR ~|~CUST STATES AIR BAG LIGHT IS ON ~|~FOUND THE LEFT SIDE SEAT AIR BAG ASSY FAILING ~|~REC REPLACING THE LEFT SEAT AIR BAG ASSY, EST 792.99".
