2012 Prius v High Beam Bulb Replacement
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Air_Boss, Sep 5, 2016.
  1. Air_Boss
    Air_Boss Senior Member
    4,236
    1,191
    New Yawk
    Has anyone replaced the 9005/HB3 high beams on their 2012 v?
    The Owners Manual literature shows a bulb and pigtail configuration that differs from what I actually find installed in the vehicle (both sides).
    This is the Owners Manual,which shows a dogleg bulb holder with bulb in line with the vehicle fore-aft axis and pigtail trailing downward at right angle (dogleg) to the car fore-aft axis that one is advised to torque counterclockwise then pull backward to remove. Like this (2013 is same as 2012, owners manula excerpt shown below):
    Toyota 2013 Prius Owner's Manual (Page 534 of 704)
    Upon inspection, however, what is actually installed on both sides is a straight-in bulb holder with pigtail trailing directly back, in line with the car fore-aft axis. So this is either not a 9005/HB3 or the bulb axis is vertical, not in line with the car axis.
    Bulb holder doesn't want to torque counterclockwise about the fore-aft axis. Don't want to treat it like a dogleg for fear of breaking the connector.
    Anyone else have a similar experience? What's the removal procedure? Thanks.
    #1 Air_Boss, Sep 5, 2016
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Post a close up picture of both the bulb from the front, reflector side, and from the back, of the bulb base.
    Are you the original owner, or did you get it used?
    The highbeam bulbs in both of my Toyotas are 9005 as in your owners manual.
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,867
    6,826
    Texas Hill Country
    If it's the halogen bulbs like mine, it does rotate 1/4 turn to remove. However the outer bulbs [low beams] have a very short and tight harness which makes it hard to rotate with the cable on. Unclip the harness first then rotate. Try the easier to access bulb (which will rotate with the harness on) to see how it works. I ended up buying a harness extension on ebay to make it easier in the future.
    #3 rjparker, Sep 5, 2016
  4. Air_Boss
    4,236
    1,191
    New Yawk
    Page from the 2012 manual attached (same). Will try to get some photos.
  5. Air_Boss
    4,236
    1,191
    New Yawk
    It's the OEM 55W LED low beam / 60W halogen high beam headlight setup.
    Photos of (black) driver side high beam lamp connector from above (white molded part is back of LED low beam lamp module), fore-aft axis is left-right, and from the side, looking from center to outboard.
    Driver's side headlight bezel from front (high beam outboard/right).
    The puzzlement is it is not the 9005/HB3 dogleg orientation connector I expected.
    #5 Air_Boss, Sep 5, 2016
  6. xliderider
    8,140
    3,277
    Honolulu, HI
    The highbeam connector has 4 wires going into it?
  7. Air_Boss
    4,236
    1,191
    New Yawk
    Yes, four wires in the pigtail to the high beam connector. The lamp itself likely only has two.
  8. xliderider
    8,140
    3,277
    Honolulu, HI
    Then that's definitely not a standard 9005 halogen connector and bulb. But you already knew that. ;)
    No mention of any other bulb types based on trim level 5, since you've got LED headlights? Have you looked on Sylvania.com?
  9. Air_Boss
    4,236
    1,191
    New Yawk
    Per every OEM and aftermarket source, trim Five is the LED low beam headlamps, which should have HB3/9005 high beams....
    #9 Air_Boss, Sep 5, 2016
  10. xliderider
    8,140
    3,277
    Honolulu, HI
    This may be dumb to ask, but are you sure that's the highbeam connector?
    Your picture from the front of the car shows the highbeams are way inboard on the headlight assembly.
  11. rjparker
    10,867
    6,826
    Texas Hill Country
    This is my driver's side high beam 9005 assembly viewed from back under the diagonal body brace. The second pic is the lamp assembly new.
  12. Air_Boss
    4,236
    1,191
    New Yawk
    You raise an interesting question,which appears to be the right one. Illuminating the lamps in the dark,the pictured connector is for the outboard low beam LED projector. Will try this again in the daytime!
    Thanks!
    xliderider likes this.
  13. Air_Boss
    4,236
    1,191
    New Yawk
    The images don't display but may confirm the above diagnosis. Thanks!
  14. xliderider
    8,140
    3,277
    Honolulu, HI
    The images show a typical 9005 bulb with the 90 degree angled base and connector.
  15. Air_Boss
    4,236
    1,191
    New Yawk
    Well, that was embarrassing!
    Of course it's an HB3/9005 and removed with a quick torque of the dog bone -- if you are at the right connector!
    Thanks to those tolerant folks on PriusChat...
  16. michael myers
    michael myers Junior Member
    Chattanooga, Tn
    2015 Prius v wagon
    I think I have the same issue op does. It looks as though most Prius have the usual setup where you just turn the bulb counter clock wise and it just slides out. Meanwhile there are the oddballs, like this :Toyota Prius V 2015-17 + Bulb Headlight Light Bulb Holder Cover Cap | eBay
    If you look at this assembly the bulb appears to go in the same way but is fed through a housing door. The door locks into place the same way the bulb does. I haven't tackled mine yet (I'm going to do an led upgrade on the high beams) The picture in the above links explains it better.
  17. rjparker
    10,867
    6,826
    Texas Hill Country
    The Op had a 2012 v which is different from your 2015v. On his trim 5 he had one factory non removable low beam LED and one factory removable halogen high beam. He solved his problem by moving his hand to the correct bulb.
    Air_Boss and michael myers like this.
  18. michael myers
    Chattanooga, Tn
    2015 Prius v wagon
    Thank you for pointing that out. I'll do a new post in case anyone else has the same issue I do.
