2012 Prius V hybrid battery issue
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by blend123, Aug 19, 2021.
  1. blend123
    blend123 Junior Member
    26
    Los Angeles
    2012 Prius V. I replaced the hybrid battery with a used one (86k miles). Before, the car would turn off within 5 minutes or less. After installing the used battery, the hybrid warning light turned off, but it came back within a few minutes. Now, the car turns off after 20 minutes or so. Is it possible that the inverter is bad? Or is the replacement hybrid battery not good? Also good to note that before replacing the hybrid battery, the car would only run with the engine. Now, the engine turns off and the hybrid battery takes over. Also, I replaced the inverter pump.
  2. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Has the inverter motor generator ECU re-flash TSB been accomplished?
  3. ChapmanF
    19,020
    Are you ever going to read the trouble codes to find out why the warning light is on?
    Air_Boss likes this.
  4. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    You probably need a new Traction Battery and a Inverter.
  5. ChapmanF
    19,020
    Finding out will involve reading the codes.
  6. blend123
    26
    Los Angeles
    What's that about?
  7. blend123
    26
    Los Angeles
    What is a traction battery?
  8. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    You might try google more.....the traction battery is the BIG Battery 200+ volts in the back of the car.
    I guess you could call it the hybrid battery but that's not the correct term.
  9. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    you need to go to the toyota website and and create a account...then you can put your vin # in there and see what has been done to the car at a toy dealership.
  10. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    My car has a fairly NEW Traction Battery and it shuts off in 2 minutes or less.
  11. ChapmanF
    19,020
    This car has the hybrid warning light showing. There's no word that anyone has read the trouble codes to find out why yet. That would be worth doing.
    Aaron Vitolins likes this.
  12. Air_Boss
    4,259
    1,197
    New Yawk
  13. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
  14. ChapmanF
    19,020
    Someday those codes will come
    Someday we'll look them up
    Then it's on to repairing we'll go
    'Stead of guessing forever, we'll know
  15. Air_Boss
    4,259
    1,197
    New Yawk
    My understanding is the TSB covers pre-existing circuit board damage prior to the reflash. You might try it.
  16. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    It should. .....
  17. blend123
    26
    Los Angeles
    The code is P0A80- Replace Hybrid Battery Pack.
  18. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
  19. ChapmanF
    19,020
    Not everybody's favorite outcome, but still it is nice to finally know what the issue is (and what other issues it isn't).
  20. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    almost 10 year old battery........
    but now only have to worry about the inverter blowing, burning oil, head gasket and the brakes going out plus the dreaded EGR System.
