2012 Prius v (lowercase v for the Prius v wagon) tire sizes
Discussion in 'Prius v Main Forum' started by lordkahless, Sep 28, 2015.
  1. lordkahless
    lordkahless Junior Member
    Hello, I own a 2012 Prius v (lowercase v for the Prius v wagon) that came with P205/60 R16 tires and they are going to need to be replaced soon. I just so happen to have a brand new set that I had bought for a previous car I don't have anymore of P205/55 R16's. Since these are slightly shorter tires will they still work with my Prius v (lowercase v for the Prius v wagon)? I was concerned that the car would sit lower and could potentially scrape something? Especially in the winter with a lot of snow, ice, slush?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    In theory, it will be 4/10 of an inch lower. (10.25 mm)
    You do not list an address, so no one can guess how much snow you get.
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    There are numerous tire size calculators, according to the one on http://www.discounttire.com/dtcs/infotiremath.do your speedometer will be off by minus 2 mph at 65 mph.
    However, you should probably be more concerned with whether the tires are low rolling resistance tires.
  4. lordkahless
    The very northern tip of Idaho. 4/10 doesn't sound like much...
  5. lordkahless
    They are not low rolling resistance tires, but to go buy another set of tires vs. having slightly worst gas mileage perhaps I break even.
  6. xliderider
    8,140
    3,280
    Honolulu, HI
    Your odometer will register falsely higher with the smaller tires as well...
  7. lordkahless
    according to an article I found online, if gas is $3.50/gallon low rolling resistance tires save approximately $33.60 per year in fuel.
