2012 Prius v (lowercase v) Needs New Engine??
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by feivel, Aug 5, 2015.
  1. feivel
    feivel Junior Member
    43
    Wow. I've bought and maintained 5 Gen-2 priuses, all second-owner, and they have never had problems. Amazing vehicles.
    I bought a new 2012 Prius v (lowercase v for the Prius v wagon) when it came out, and added the 125,000 ToyotaCare Platinum warranty onto it.
    At 135k miles, the engine just, um, cracked? I'm not getting good details yet, but I'm being told that I have to have the entire engine replaced, and they're asking $5500 to put a used motor with 80k miles into it.
    This is ridiculous. Is there a way to get this covered? Clearly the engine is designed and sold to last for more than 3 years / 135k miles. I even bought the warranty just in case!
    Just got this from the service department at the Toyota dealership:
    ENGINE ASSY FAILED CAUSE ENGINE PISTON SLIPPED INSIDE MOTOR AND MADE 2 HOLS IN ENGINE BLOCK CAUSING LOSS OF OIL WHICH CAUSED ENGINE TO FAIL
    #1 feivel, Aug 5, 2015
    52,695
    find a local mech, they will do it much cheaper than a dealer. things happens, maybe someone forgot to check the oil.:cool:
  3. feivel
    43
    Can anyone here recommend a good "local mech" in the Philadelphia or NYC, NJ area to work on a Prius v (lowercase v for the Prius v wagon).How much could it save?
    In the other direction - can the engine be claimed under CARB standards warranty to 150,000?
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,886
    6,832
    Texas Hill Country
    "Cracked" is not much of a symptom. Cracked block, cracked head, cracked manifold? Some of those things can be fixed. Did you drive it in? How was it running? There have been people that had a completely wrong diagnosis in the past. Second opinion is in order.
    Hybrid Repair and Battery Services - Philadephia, PA
    or
    10 Best Prius Repair Shops Philadelphia, PA on Mechanic Advisor - Reviews, Coupons, and Services
    These guys may not do engines but they should be able to tell you who does on a Prius.
    #4 rjparker, Aug 5, 2015
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I would be disappointed if that happened to me with a vehicle less than 3 years old.
    As people often do when their HV battery fails just past warranty it probably wouldn't hurt to call Toyota Customer care and plead your case. All they can say is no.
    As the Gen 3 vehicles age, I hope this doesn't become a common occurrence. So far yours is the only report of the engine spontaneously cracking that I've read. I would like better details as to what cracked, just so it can go on record for further comparison.
    You might of just got unlucky. As streamlined and precision as modern production can be, occasionally flaws happen. With proper maintenance, and no accidents, I would expect more than 3 years and 135,000 miles.
    Good Luck.
  6. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    you have few options really
    buy a used engine from a salvage yard and hope for the best
    buy an entire wrecked low mileage car and use the engine than sell the other parts
    rent one for a week and swap motors
    report it stolen and push it into a lake
    seems odd, Gen 3 NY cabs hit 250,000 or more miles before they are retired and sold on e bay with original motors and batteries.
    maybe you got the bad one
    good luck
  7. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Something tells me there's a lot more to this story than thus far posted. But as mentioned, just because the dealer says it needs an engine doesn't mean it does.
  8. feivel
    43
    We did regular oil changes and hadn't been having any problems before this occurred.
    Now what? They offered to install "USED ENGINE WITH 72K 2200.00 3294.00 IN LABOR 1YR WARRANTY"
  9. Air_Boss
    Air_Boss Senior Member
    4,237
    1,192
    New Yawk
    Rod or rod cap failure?
  10. Beachbummm
    1,160
    392
    2200 for the USED motor is insane
    3295 for labor is a lot worse, find a motor on your own and a local shop to install it.
    start your motor search on e bay if you find one ask if they install, should not be over $2500 total
    heres one on e bay with 7.000 miles for $800 2012 1.5 liter
    2012 Toyota Prius Engine 1 5 Motor 7K | eBay
  11. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    He needs a 1.8L engine, not 1.5.
    I still say there's more to this story. But in any case it should be given over to corporate reps for evaluation and possible assistance. DO NOT trust the dealer.
  12. feivel
    43
    Thanks for this great help. How do I reach useful corporate reps?
    #12 feivel, Aug 5, 2015
  13. JACoH
    JACoH Enjoying the mileage
    193
    40
    Oregon
    Phone/Fax
    Phone:
    800-331-4331 Fax:
    310-468-7814
    M-F 5:00 am - 6:00 pm PT
    Sat 7:00 am - 4:00 pm PT
    Email
    Before you email us, please check out our FAQ section. Many of our visitors have found quick answers to their questions by searching our FAQs.
    Email Us
    Postal Mail
    Toyota Motor Sales, U.S.A., Inc.
    19001 South Western Ave.
    Dept. WC11
    Torrance, CA 90501
  14. Estela13
    Estela13 Member
    Interesting was your v burning any oil?
    I've had to keep an eye on mine currently @ 250K miles on my 2013
    No major issues here
    SM-G900T ?
  15. frodoz737
    frodoz737 Top Wrench
    4,784
    2,549
    33
    Something smells really bad here. Contact Toyota Corp before the Dealership does anything. I am more than certain they want to know about this.
  16. Air_Boss
    4,237
    1,192
    New Yawk
    Agree.
  17. bisco
    52,695
    no doubt it threw a rod through the side of the engine. more likely ran out of oil first.
    call around to aaa shops etc. for used engine replacement pricing. talk to the about prius and make sure they have experience.
    the engine is not part of the hybrid system, so only 3/36 warranty.
  18. Air_Boss
    4,237
    1,192
    New Yawk
    Any low oil pressure indication before the failure?
    When was oil last changed, by whom, and how often do you check oil level?
