2012 Prius V No Response to Power Button
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Nick Velikonja, Apr 25, 2025.
  1. Nick Velikonja
    Nick Velikonja New Member
    Hi All,
    I'm working on a friend's vehicle, and we're the last resort for this dead prius thats been at another shop for a month. The story is that the vehicle was stolen (with the key still in it), driven, and then left somewhere. Before they left it, the thieves cut off the start button... We don't know why. My friend soldered the wires back together, but now there is no response to the button at all. However, there is ok voltage ~12v in the starting battery, and the power door locks work.
    Code B2784 is set. They tried another button, same thing. The recertification appears to work, waveform on the CODE and TXCT circuits look like communication. The power source control module also appears to work, as live data shows that it sees the button turning on and off. I havent figured out yet how to test the INDW and INDS circuits.
    What am I missing here? Even without a good key, shouldn't the dash turn on and flash an immobilizer light?
    52,879
    maybe a fuse blew?
    Air_Boss and Brian1954 like this.
  3. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    At one repair shop, their mechanic bought a 07 avalon with the very similar problem. The car sat for several years. The door locks work from the fob key. The start button does not respond at all. He bought a second avalon for parts with almost 300k miles, run and drive. He tried to swap all the computers into a non-working car but nothing changed. Still no signs of life. The owner changed the fuse box under the dash, but still no changes. Checked all the fuses. Swapped the computer on the side of the fuse box in the engine compartment.
    There are 2 indicators on the dash: the door is open and the red key indicator is flashing.
    Stepping on the brake pedal, the start button does not turn green even though the brake lights are on.
    There is no sound that the door is open.
    I've checked all the fuses myself. Checked the grounds, the power supplies on the computers. Everything looks fine. I swapped all the computers into a working car and pressing the start button, a signal beep occurs and a yellow light on the dash comes on telling key not found.
    My guess is that there is still no power somewhere or the communication network is interferenced by something.
  4. tony_2018
    tony_2018 Member
    227
    68
    I would suggest getting an account for toyotas wiring diagram to trace.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,981
    Texas Hill Country
    You should see the immobilizer light blink but without a good key fob you will get nowhere.
    If someone cut the Ready button it sounds like amateurs trying to hot wire it. Maybe after the first crew. It would be easy to think they tried other things as well.
    A dealer would be able to clear the immobilizer ecu (with locksmith permissions through Techstream ) and setup a new fob which would ultimately be needed. They would then be in a better position to diagnose the no start as well.
    tony_2018 and MAX2 like this.
  6. Carall
    316
    104
    Harrisonburg, VA
    Yesterday I checked the LIN bus in this Avalon and it turned out that the transponder key ecu is bringing the LIN bus down to 1.6 volts. After I disconnected the connector with the LIN bus wire for the transponder key ecu in the passenger junction block, the LIN bus returned to ~11 volts.
    The transponder key ecu in this car located behind the HVAC box, in the center of the dash.
  7. tony_2018
    tony_2018 Member
    227
    68
    Probably blew a wire/circuit.
