2012 Prius v starts (and drives) without key. How can this be?
Discussion in 'Prius v Main Forum' started by Plhys, Dec 21, 2020.
Tags:
  1. Plhys
    Plhys Junior Member
    My 2012 Prius v wagon starts without a key. There is a blinking light that seems to be a graphic of a key in the lower right corner of the display when the car is off. The display is normal when the car is on except for a "needs air" tire symbol and a needs maintenance light.
    I have not driven the car much for the past several months because it overheats when driven above 50 mph. The battery went bad during the period I was not driving the car and I first tried to start the car with a battery charger set to the start position (after charging the battery) and then replaced the battery with a new non-Toyota battery and the car started right up.
    I probably drove the car 8 times over a 7 month period. During the 8 month period, I assumed the key was in the car but did not know exactly where the key was. I just figured I would find the key when I decided to take the car to a mechanic. The car has 212 k miles on it.
    Today I decided to take the car to a mechanic, went out to the car and it started right up. I looked for the key and could not find it. I then took everything out of the car except for the spare tire and jack and did not find the key.I had a friend who looked for the key. He could not find the key. I hired someone to vacuum out and generally clean the car. She did not find the key.
    I drive the car back and forth in the driveway and then around the block but have not driven it on the road otherwise. I parked the car on the road in front of our house, about 150 ft away from the stuff I took out of the car and the car still starts without a key. The blinking key emblem still shows when the car is off.
    I guess I have 2 questions. Is this possible? If it is not possible and the key must be in the car somewhere, is there some obscure hidden niche in the 2012 Prius Wagon that I should look in?
    I searched Prius Chat for a similar issue. One person reported similar behavior in a Gen 3 Prius and was accused of being a troll. I am not a troll, just a puzzled person.
    Thanks,
    Paul
  2. Plhys
    Plhys Junior Member
    By the way, I just had one key and maybe now have no keys at all. Yes I know, I am an idiot for not getting another key when I was down to 1 key.
    Paul
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    Did you look in the pull out cup holder under the top console cup holder? There is also a removable tray in that cup holder with room underneath.
  4. Plhys
    Plhys Junior Member
    I went out and doubled checked the pull-out cup holder. It wasn't there. The removable tray was apparently removed before I ever bought the car. I initially misread your post and tried to pull out a holder from cupholder #1. As I'm sure you know the silver ring pulls off but cupholder 1 is built into the console.
    I appreciate the suggestion.
  5. bisco
    52,874
    maybe the second key is lost in the car somewhere
  6. Plhys
    Plhys Junior Member
    Maybe so. Athur Doyle had Sherlock Holmes say: "(.when you have) eliminated the impossible, whatever remains, however improbable, must be the truth". I've taken everything loose out of the car. It seems impossible that the key is inside the car . . . but the car starts.
    So my (somewhat revised) question is: is it impossible for a 2012 Prius v to turn on if a key is not inside the car? Because if it is impossible for the car to start without a key the key must be in there somewhere and I need to continue searching until I find the key even if I have to remove seats and carpet to find the key.
  7. rjparker
    11,125
    6,980
    Texas Hill Country
    By the way, the bottom right indicator light is the security system. On a Toyota it is called the Immobilizer System. It always flashes with the car off. It will only go off if you push the Power button WITH the keyfob inside the car. Which is what your car is doing. Plus it goes to Ready and runs only with the keyfob inside the car. FE931D0B-E215-4BE6-B1F7-CE41D1990EF7.jpeg
    scona likes this.
  8. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    So begins the find-the-key interior teardown...
    Raytheeagle likes this.
  9. rjparker
    11,125
    6,980
    Texas Hill Country
    Do you have a remote start in the car? They did not come standard.
    Given that you took the car 150 feet away and it still started and drove, I believe the fob is in the car. I would at least take out the front and back seats. I might unhook the glove box tabs to access the area behind it. There are some air ducts under the seat as well.
    Otherwise you could make an appointment with the dealer to buy a new fob and have them program it to the car. They could then disable the current one in the car's ecu. You need to do something before the current fob dies due to weak battery.
    Note to moderator: it took over 24 hours to allow this guy's response to be viewed.
    #9 rjparker, Dec 22, 2020
  10. overexposure
    overexposure Junior Member
    amsterdam
    With your key outside of the car press the button on the main door handle ( drivers side ) to close the car , if the car closes there is no key in the car remaining. If it beeps the second key is somewhere in your car
    Air_Boss likes this.
  11. rjparker
    11,125
    6,980
    Texas Hill Country
    Check the second post. He does not have a second key. In the first post he indicates he drives the car around and has parked it 150 ft away and it still starts.
  12. Landon51
    Landon51 Member
    190
    63
    US
    I didn't have time to read all the replies. Look at the place where you can insert the key before pressing the start button.
    You are looking for a small chip that is located in your key. this allows you to bypass security and start the car.
    To start the car, you just need that little black chip. All the other circuitry is just to open the door when you walk up to it.
    For a while with a Corolla, i had it taped to the little ring where you turned the key. That Allowed me to use a metal key when everyone else has this big bulky key.
  13. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    Pull out the #10 fuse in the fuse box under the left dash. That deactivates the Smart Key system. If there is a key in the car, it should not start. That will definitely verify that there's a key in the car.
    If you can not find it, you can use Techstream and take it off the list of functional keys. If you ever find it, it can be readded.
    Mendel Leisk, tvpierce and Air_Boss like this.
  14. rjparker
    11,125
    6,980
    Texas Hill Country
    Any update?
  15. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    @Plhys
    How did you make out? Any developments?
  16. qmanqman
    qmanqman Active Member
    444
    153
    CO
    It is possible a fob was busted apart and the transponder chip still in the car somewhere? The chip is tiny. Here's what it looks like in my Accord. What does it look like in this Prius? Accord Key Fob.png
  17. rjparker
    11,125
    6,980
    Texas Hill Country
    The transponder only works without power when it is held next to the power switch.
    Gandolf989 likes this.
  18. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    I would think someone would notice if their key fell apart.
  19. rjparker
    11,125
    6,980
    Texas Hill Country
    This guy only had one fob and he can't find it. But the car starts and runs.
  20. Mendel Leisk
    42,361
    @Plhys : not sure if this has been asked, do you have touch-to-lock/unlock, and is it working? Seems to me if fob was in car you’d get long warning beep and it wouldn’t lock when you try.
