2012 Prius V suddenly stopped working on road
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Amily, Feb 28, 2021.
  1. Amily
    Amily Junior Member
    17
    FL
    Update: code P01A1A. My 2012 Prius suddenly stopped working when I was driving on the road, looks like all light on, please see pictures. I slowly drove it to the side road.
    Now it was towed to my home. It won’t start anymore. I Checked the 12V battery, and I also unplugged the negative of the 12V battery and replugged, but it didn’t work.The 12 battery is only 2 years old.I checked the main fuses which are look good.
    Finally I got code P01A1A which meets one of the code of ZE3, but I didn't get any recall and mine is 2012 Prius, should my car be covered by ZE3?
    I appreciate any suggestions.
    #1 Amily, Feb 28, 2021
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I think that having it towed to a dealership or other hybrid repair shop might have been a better choice.
    How exactly did you "check" the 12 V battery ?
    Did you also check the main cable connections to it ??
    At 9 years old with over 100K miles, there could be a LOT of things that might be suspect.
  3. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Start with 12V verify it is still good.
    moto g(7) power ?
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Sounds a lot like when the Gen 3 inverters were failing during operation. All lights on, and only able to drive in limp mode.
    I believe if the inverter has failed, it might be covered.
    jzchen likes this.
  5. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Was the Inverter/Motor/Generator TSB ever accomplished?
