2012 Prius v Unicorns and rainbows
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by cantsitstill, Apr 5, 2016.
  1. cantsitstill
    cantsitstill Junior Member
    Bought new- babied - garaged - dealer serviced - not a brake rider or two footed driver.
    How is it even possible this thing needs rear brakes at 17kmi???
    Yes. Seventeen thousand miles.
  2. Air_Boss
    Air_Boss Senior Member
    4,241
    1,192
    New Yawk
    How has your mpg been? Wear rate suggests brakes have been dragging. Caliper slide pins lubricated?
  3. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 Prius is still on its original brakes at 285 kmiles. Our brakes last a loooong time due to regenerative braking. The only problems that occur are rusted rotors due to lack of use and corroded sliding pins (can cause uneven pad wear) due to lack of maintenance (lubricate them every few years).
    JeffD
  4. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    Something has gone very wrong if new rear brake pads are needed. We have only 21,000 miles on our 2012 Prius v but I expect that its rear brake pads will be "lifetime" (> 200,000 miles) based on my experience with three non-hybrid Toyota vehicles that have been driven to far over 100,000 miles on the original rear brake pads.
    Could you provide more information? For example, who is telling you that the pads are worn out? Have you personally verified the wear by measuring the pad thickness? Any other relevant information?
    I don't know what the minimum acceptable pad thickness is for a Prius v but on our other Toyota and Lexus vehicles, the minimum acceptable thickness was only 1mm. I've had repair shops and even Lexus dealers tell me that brake pads were worn out even when they were not even half worn out - very common scam.
    CR94 and Mendel Leisk like this.
  5. cantsitstill
    Average for life of car is 38.5
    Not a scam garage. I've brought cars to this guy for 20 years. He happily shows parts and gives options. It was just in for inspection, and he said it passed, but barely.
    He also knows that I used to build trail Jeeps, so BS won't pass. I just don't like to wrench anymore...
    It's my wife's car and I don't care to work on it.
  6. rjparker
    rjparker Tu Humilde Sirviente
    10,921
    6,853
    Texas Hill Country
    Unlikely but it sounds like your mpg is down at least 4 mpg. 38 mpg is what I get doing 75-80 mph. So perhaps they were dragging. Do you have salt on your roads in winter. Location in your profile is more than a nice to know, it helps diagnose some items.
  7. bisco
    52,731
    did he show you the pads, rotors and operation? fronts usually wear first, unless somethings wrong.
  8. Mendel Leisk
    42,211
    Did they say if it front or rear brakes, or both? If you're a veteran wrencher I'd at least pull both a front and back wheel, see what's going on. The miles per gallon sounds kinda low, but it is the v, so not sure.
  9. Offline
    646
    240
    Lenexa, Kansas
    I don't know how rjparker is getting the gas mileage he is getting but 38.5 mpg is right at what our 2012 Prius v Five has gotten over its 21,000 miles and I check it at every fill-up. It's my wife's daily driver and driven about half on 55-65 mph highways and half on city streets where the speed limit averages 35 mph. She drives it like a regular non-hybrid car and doesn't strive for low fuel usage. Its tires are kept near the recommended pressures shown on the door jam: 33/32.
    Maybe your trusted mechanic simply made a mistake and "eyeballed" it instead of measuring the pads.
    I suggest you pull one or both rear wheels and measure the pads yourself. If you don't have an appropriate measuring tool, use a hard wire such as a length of wire coat hanger to gauge the pad thickness and then measure that portion of the wire with a metric ruler. I've been measuring brake pads for decades and lengths of coat hangers are some of my favorite tools. Seriously, I've got them hanging on a hook in the garage.
    And maybe aim a cell phone camera at the pads and show us what their thickness looks like.
    If you have a floor jack, the Prius v is super easy to lift from the front or rear - I did it just last week when I switched out the snow wheels. There is a big body color metal "nub" hanging underneath the back of the Prius v for lifting the vehicle with a floor jack - it's fairly far forward from the rear bumper. That reminds me that I need to re-torque the lug nuts since the car has been driven a bit - 76 ft. lbs. is the spec.
  10. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    A normally operated Prius with normally functioning brakes should see at least 75,000-90,000 miles on a set of rear brakes. Absent any real information about what exactly is "wrong" with your brakes its most likely you are being ripped off. OR, at best the mechanic is clueless.
  11. Air_Boss
    4,241
    1,192
    New Yawk
    2012 v Five with 31,000 miles on original F/R pads, TP 40/38psi, lifetime 43.0 mpg
    I just don't know how you could go through rear pads in particular in 17,000 miles.
  12. Mendel Leisk
    42,211
    One way the rears can wear fast: if they'd been disassembled, and reassembled wrong. The incorporated parking brake mechanisms require specific orientation of the caliper piston. Mis-orientation causes terrific drag and uneven wear.
  13. Air_Boss
    4,241
    1,192
    New Yawk
    OP doesn't mention any such work having been done. That is one possibility, of course, but it would presumably be noticed while driving, in mpg drop, and you'd smell overheated brake material.
  14. cantsitstill
    After today's research, I'm going with lack of driving leading to sticky brakes and uneven wear.
    Dealer on 4-26. I will get the old parts. I have a business to run, three properties to look after, and a master bath reno to finish. No time to heat up the garage and wrench on my beautiful wife's car.
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  16. Offline
    646
    240
    Lenexa, Kansas
    I think your conclusion is likely the most accurate - that the mechanic was not familiar with Toyota vehicles and did what he thought was appropriate.
  17. mikefocke
    4,071
    1,856
    Sanford, NC
    Just had a 30k miles service on a 2012 v. Mixed city and highway miles.
    Inspection report gave me still 10mm for the fronts pad thickness, 11mm for the rears. And 10/32" for the tires.
    My last car needed an $1,100 brake job at 30k and $1,200 in tires every 15k so you know I'm not babying things.
  18. cantsitstill
    $1200 in tires? Holy crap, that's expensive. I just put 20" Nitto Terra Grapplers on my Grand Cherokee for $1000.
    Man, this little car looks like it's gonna be costly.
  19. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    OTOH, you have yet to demonstrate that there's anything wrong with the brakes.
  20. bisco
    52,731
    mike mentions his 'last car' needing $1200. in tyres, and suddenly, the prius is going to be expensive?
