2012 Prius v Unicorns and rainbows
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by cantsitstill, Apr 5, 2016.
  1. mikefocke
    4,071
    1,856
    Sanford, NC
    The car I was citing was a Prius v. The car with the expensive brakes and tires, a Porsche.
    My 30k Prius v at 4 years has cost me a set of windshield wipers and a 30k dealer service. I consider that very cheap.
  2. cantsitstill
    cantsitstill Junior Member
    Probably better off to put her back into something fun to drive so it actually gets some miles on it.
    #22 cantsitstill, Apr 6, 2016
  3. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    Your Prius is being driven far more than an adequate number of miles to keep it in good working order. Many car collectors drive their cars no more than a few hundred miles each per year to keep them in good working order. Even car museums, of which I have toured many, have their vehicles driven just a few miles each year to keep everything in order.
    The probability that your Prius needed a rear brake job at 17,000 miles is infinitesimally small. If your mechanic has already done the work, you can either write it off as a mistake or surmise that he had a boat payment due.
    Sometimes I think I would be better off if I didn't have the level of automotive knowledge I have. "Ignorance is bliss" but can be very expensive.
  4. Kenny94945
    Kenny94945 Active Member
    861
    437
    Sausalito
    2016 Prius v wagon
    Reads like the OP doesn't have the time to "work" his Prius so he is "at the mercy" of others.
    17K mileage for brakes is rare...even with a streeted sport car none the less a Prius.
    Really need to remove rims and re-inspect. Sticky caliper piston, pads hanging on retainers, pads compound binding again failed, mis-read remaining pad thickness by mechanic, out of round rotor, computer traction control/ bounce jounce issue perhaps?
    So, OP should get a second opinion.
    Seems he is and has scheduled an Apl 26 dealership appointment.
    OP please let us know the outcome!
    Good luck.
  5. mikefocke
    4,071
    1,856
    Sanford, NC
    And ask for any removed parts.
    cantsitstill likes this.
  6. bisco
    52,731
    probably better of just to put her into something more fun to drive, and put this whole regrettable incident behind you.
  7. cantsitstill
    Service Saturday- We will see what dealer says- and see parts.
    Can't get her out of the car... She just got 50mpg on a 130 mile round trip over the weekend.
    Loves it- backup beeper and all
    I can't drive the car, or ride in it, without lower back pain, so we always take my gas hog Jeep that I need for frequent towing of trailers. This is why the v gets 4,000 miles a year. Car will rot out with the NY winters before it ever sees 100kmi
  8. bisco
    52,731
    we hear a lot of complaints about the seats. most can tolerate them, but some have pain like you. nobody loves them.
  9. cantsitstill
    Image1461437826.148320.jpg Image1461437838.734246.jpg Image1461437849.077351.jpg Image1461437859.714592.jpg
    New rear pads and rotors. 16,843 miles.
    The seat position is all wrong for me. True.
  10. Offline
    646
    240
    Lenexa, Kansas
    Those are amazing photos. The brake rotors on our 2012 Prius v are still shiny, bright and like new after a bit over 23,000 miles although, granted, not as much salt is used on roads on Kansas and Missouri where ours is driven and the last few winters here have been unusually mild.
    I've always made it a practice to blast rotors and calipers with hot water at a car wash every week or two year round although I usually wimp out and don't do it when temperatures are below about 20 degrees Fahrenheit. Do you have other vehicles parked in the same garage that are driven at about the same rate and not having this problem? The reason I ask is that heated garages can accelerate corrosion dramatically if vehicles are driven on salted roads and not adequately cleaned.
    Yes, the front seats are horrible for many of us including me. There are threads on this forum about that.
  11. Air_Boss
    Air_Boss Senior Member
    4,240
    1,192
    New Yawk
    Classic 'YMMV' stuff. 30,200 miles on the original pads all around. Absolutely love the front seats and perfectly placed and raked head rests (for the 6'4" driver, at least).
  12. bisco
    52,731
    are you in the 'rust belt'?:p
  13. cantsitstill
    Central NY - problem is the sub 30 mph, 20 miles a week that it gets driven from No ember to April - then it sits Friday, Saturday, Sunday.
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I hate to advise you to waste energy, but if you brake in N once in a while, all the braking will be friction braking, which can scrub rust off the rotors. Just an idea.
  15. bisco
    52,731
    there's another thread here, about lubing the slide pins on the rear brakes. seems that the design is poor, and premature wear can occur if the calipers stick. they recumbend every 30k, but in your case, it might be a much shorter interval of inspection and lubrication as necessary.that's 1,000 miles per year?
  16. cantsitstill
    Winter only. Now through November, she will drive 200+ per week
  17. bisco
    52,731
    gotcha. you really have a very unusual case there. i haven't seen anything like it. mine is 4 years and 40,000 miles, and my garage is very moist, collects rain and snow from the car. front and rear pads and discs look like new, except the heavy build up of rust on the very outside of the rotor where the pads don't touch. it will be interesting to hear updates if you decide to keep the car. all the best!(y)
  18. Victor A. Rivera
    Victor A. Rivera New Member
    San Juan, PR
    My 2012 Prius v (lowercase v for the Prius v wagon) has 107K and still have the same brake pads...
  19. Boston Jim
    Boston Jim Active Member
    202
    148
    I just had rear pads put on my 2012 Prius v with 44k miles which I thought was a bit early, the rear were down to 4mm, the front were still at 6mm with the rear rotors a bit rusty. Although just sitting for a couple of days both the front and rear rotors tend to rust up pretty quickly around here.
    The one caveat, I also had the annoying issue with the very loud brake noise/squeal with the rear brakes after sitting overnight within the first year. I took it in at least twice before it finally stopped, not sure what they actually ended up doing to 'fix' it.
