2012 Prius V Wagon Issues After Safety Software Update
Discussion in 'Prius v Main Forum' started by hellonearth, Jun 29, 2019.
  1. hellonearth
    hellonearth Junior Member
    35
    My 2012 Prius V Wagon has been having issues since the safety software update. I first noticed the car selectively (hit or miss) going in EV mode even after driving over 30 miles on the freeway so its not a matter of the engine and or fluids not heating up. The EV light also rarely lights up while before it was fine. It idles a lot without going in EV mode.
    More worrisome is the intermittent acceleration cutting out recently with the warm weather (85F Plus). I have been having scary on and off acceleration issues with the AC on when the car will decide not to accelerate until I turn the AC off even if i floor it. When I turn the AC back on, the car would slow down again. This happens occasionally and usually when the it is quite hot outside.
    Anyone else experienced similar issues or can point me to another thread. I love the car and it only has 92K miles on it but the acceleration cutting out is quite scary and a safety issue especially on the freeway. Thanks!
    #1 hellonearth, Jun 29, 2019
  2. Air_Boss
    Air_Boss Senior Member
    4,261
    1,197
    New Yawk
    What software update campaign number are you referring to? Not aware of a “safety” update, though there have been two hybrid system firmware updates since 2016.
  3. hellonearth
    35
    It is the most recent hybrid system update that supposedly prevents the Prius from stalling. I will try to find the paperwork and post the number
    52,895
    sounds like the inverter diode update to limit accretion to prevent overheating
    clean the battery cooling fan and grille
    check the 12v health
    clean the egr circuit
    check the inverter fluid movement
  5. hellonearth
    35
  6. Air_Boss
    4,261
    1,197
    New Yawk
    That's interesting. Seems to confirm earlier concerns that there may be a long tail on the inverter problem.
  7. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    How many miles have you put on since the software update? Mine acted “differently” for a couple hundred. Then it settled back into what I remembered before the update.
  8. hellonearth
    35
    Took it to the stealership where it cost nearly $700 to replace the intake manifold, clean the EGR and replace the spark plugs. He said it was all carboned up and was throwing a lot of codes. I thought price was on the high side but I bit the bullet as we are moving and I needed the car fully functional. Isn't there a TSB or some other warranty on these issues. Mine is a 2012 with 92K miles and I bought it used so not even sure if i would be covered.
  9. Air_Boss
    4,261
    1,197
    New Yawk
    Were all the inverter TSBs done?
  10. hellonearth
    35
  11. bisco
    52,895
    plug your vin into the toyota owners website. it will give you all the warranty recalls. some gen3 had an intake manifold recall
  12. Air_Boss
    4,261
    1,197
    New Yawk
    No manifold recall on the v.
  13. tommy Wang
    tommy Wang Member
    40
    38
    industry, CA 91789
    2017 Prius v wagon
    i have been at Hybrid pit and notice many of the 3rd gen Prius are going in for EGR cleaning, many of 3rd gens have at least 90K to 100K miles on them and due to the hot weather many of them are experiencing inverter issues. i guess i will be looking forward to that when my car hits the mileage
  14. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
  15. Air_Boss
    4,261
    1,197
    New Yawk
    Quote from a previous article: “Hogan, however, contends Toyota is trying avoid a multibillion-dollar replacement program for the defective inverters.” Hmmm....
    Mambo Dave likes this.
