2012 Prius vibrates and shakes while accelerating/coasting with ice
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Markski037, Jan 4, 2020.
  1. Markski037
    Markski037 Junior Member
    New Britain CT
    Hi got a 2012 Prius with close to 170k miles, just recently started getting this vibration only while coasting and accelerating with the ice. Nothing while in ev mode or full throttle with the power in the red. Put it in maintenance mode nothing on idle either. Only happens in the eco section. Two videos attached
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Sounds like a bad head gasket
    52,876
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    What is engine coolant level and is it stable?
  5. JC91006
    16,937
    8,647
    Ever changed the plugs?
    Check oil?
    Raytheeagle likes this.
  6. Markski037
    New Britain CT
    Got the engine transplanted at about 160k with a much lower milage ice , because the head gasket went on the old one and and I've bent one of the push rods and it destroyed the block. No check engine lights, oil level is stable doesn't burn. Coolant is also at same level. When my previous head gasket went I was getting a misfire on cylinder 1
  7. JC91006
    16,937
    8,647
    You probably have a bad engine mount
    dig4dirt likes this.
  8. Mendel Leisk
    42,361
    160K, 170K, seems like the usual for the failed head gaskets. Was EGR and intake manifold cleaned on either?
  9. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Was EGR passages (EGR cooler, valve, pipe, intake manifold) cleaned when you got the engine replacement?
