2012 Prius when to drain or flush coolant?
Discussion in 'Gen 3 Prius Main Forum' started by Darth_Eric, Apr 18, 2024.
  1. Darth_Eric
    Darth_Eric Junior Member
    San antonio, texas
    Just hit 120K in my 2012 Prius. Been running great no problems. Got a big road trip in a couple weeks. I’m going to replace the spark plugs, and put on new brake pads. I was wondering when is a good time to flush or drain and fill the pink coolant. I have a big jug of the OEM Toyota pink coolant. Also when is a good time to replace the coils? At 120K I figured those will be fine for awhile. A lot of people are saying to change the water pump out but if it’s still working fine I don’t see why spend the money now to change it out l.
  2. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    Check the maintainence book. It will tell you.
    But now is a good time to replace the engine coolant and inverter coolant.
    Only use Toyota fluid. Can't go wrong with that. Mixing coolant is not good.
    Spark plugs are due. The coils are fine. 335,000 miles on mine.
    Unless you have an issue with them.
    Are your brake pads worn out? Or are you just replacing them, because?
    120,000 miles is not alot for Prius pads, unless you are hard on the brakes.
    #2 ASRDogman, Apr 18, 2024
  3. Mendel Leisk
    42,341
    Toyota USA says 100K miles or 10 years* for the first engine coolant change, and 150K miles or 15 years* for the first inverter coolant change. FWIW, Toyota Canada says 160K kms (~100K miles) or 10 years* for both. After the initial change, it's 50K miles or 5 years* thereafter, for both.
    * whichever comes first, miles or years
    I did a summary of the event-by-event schedule in the Toyota USA Warranty and Maintenance Booklet, attached:
  4. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    " A lot of people said..." Be careful who you listen to. A lot of people are wrong
    Why are you replacing the brake pads?
  5. BiomedO1
    BiomedO1 Senior Member
    4,589
    2,409
    Left Coast
    If your using OEM Toyota coolant, a simple drain and fill is good enough. Do both inverter and engine coolant at the same time to save downtime.
    Dealers and mechanics will try to 'sell' you a flush, for more money. The only time that's needed is if your changing away from OEM coolant or you've got contaminates in your cooling system. Sometimes they just do a drain n fill, then call it a flush. I've seen that happen.
    That's why the OEM manual states 5 years or 50K mile there-after the initial change. The engineers know your not getting all the coolant out of it. Some old residual mixing with the new stuff. That's the other issue with a flush - unless your using concentrated coolant, you won't be able to get the concentrations correct - unless your using a flush machine. The flush machine will also mix new and old coolant.
    Just my 2 cents....
  6. Mendel Leisk
    42,341
    Maybe “flush” is in fact synonymous with drain and fill? Seems like.
  7. BiomedO1
    4,589
    2,409
    Left Coast
    bettergolf likes this.
