2012 Prius won’t start
Discussion in 'Gen 3 Prius Technical Discussion' started by Jenpen, Nov 28, 2023.
  1. Jenpen
    Jenpen Junior Member
    43
    san Antonio
    I have a 2012 Prius and I had not driven it for several days and it would not start, zero power no dome light no power locks. I used a battery pack and jumped it from the battery. It started fine, ran fine no warning lights. Drove it 25 miles on the highway, turned off and flat dead again. I am getting a new battery as it is four years old. Does this sound like strictly a 12v battery issue? Anything I should be aware of before replacing the battery? Thanks
  2. JC91006
    16,889
    8,625
    Yes just a battery issue, a new battery should solve your problems (since you can jump start without issue)
    V Sport Wagon and Brian1954 like this.
  3. Jenpen
    43
    san Antonio
    Awesome thanks
  4. ASRDogman
    ASRDogman Senior Member
    7,933
    4,039
    Just make sure you charge the battery for at least 8 hours at 4amps or less so that it
    will have a full charge from the start. The inverter won't charge it as well, and it's slow.
    nicoj36 likes this.
