2012 Rear Shock Replacement - Adjustable Air?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by feivel, Sep 19, 2021.
  1. feivel
    feivel Junior Member
    43
    150k miles on my Prius V and one of my rear shocks is leaking. I want to replace both.
    Almost weekly I have been loading the vehicle up (under GVWR) to haul building materials, or sometimes pulling a trailer. I love this car.
    This video makes replacement look easy:
    I want to replace them with Adjustable Air Shocks, like this: https://www.monroe.com/products/carry-the-load/max-air-adjustable-shocks.html
    Does anyone know the specs of the Prius v shocks, or can help figure out which size of these will be an exact fit? They don't sell any specifically labeled to fit a Prius V (but they should!)
    Thanks!
    #1 feivel, Sep 19, 2021
  2. feivel
    43
    Okay, some updates:
    Found the specs here: https://drivcat.com/overlays/part-detail.aspx?brandId=MS&pNum=5502&partType=Shock%20Absorber%20-%20OESpectrum
    Looks like model 5502 is the exact-fit for Prius V.
    Found the catalog with specs here:
    Monroe Strut and Shock Measurements - Shockwarehouse.com
    Looks like there's nothing that's an exact match, but MA777 kinda looks like it might fit maybe, but I'm not sure. Not everything is a match, but it seems fairly close. Thoughts?
    MA777 Monroe Airshocks Pair Ford E150 Van - Shockwarehouse.com
  3. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    The Hatchback and v have different front and rear shocks. Make SURE you get shocks for the v.......!
  4. feivel
    43
    *Sigh* - The Max Air ones don't have the right width of connector at the bottom, and I don't think I want to risk filling in the width with washers/spacers. So I went with the exact-fit-nothing-special replacement. Fit fine.
    Would still LOVE any advice on safely putting adjustable rear shocks onto this beast.
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
  6. redv
    redv Junior Member
    Maine
    It seems that Firestone makes pneumatic lift bladders which fit inside the coil springs on the V. I used the product in a 4Runner when I was overseas. They worked great for that. You might want to check them out.
  7. davev1pa
    davev1pa Junior Member
    34
    Lincoln,NE
    Two Eco
    Firestone Coil rites: I bought mine at etrailer.com and they’ve worked well for four years. I do want to take them out and put them on my 2016 however, I would have to disassemble the and pull them out from the bottom of the spring. I don’t see a way of getting them out otherwise. when I bought these, they were $100 now they’re 130. I will say this that they do leak air, but they’ve actually provided great lift for my trailer. I find the installed super easy, just slipped the bag into the coils and pull it down. There’s also a rubber portion that goes at the bottom that’s easily installed. You have the option to combine the two bags or run them separately. I chose separately to ensure leak proofing. They hold 30 pounds and probably gave me an inch and a half to 2 inch lift. I do have slow leaks in them, likely from connections and I could redo those, but they definitely hold air for a decent amount of time. On my 2016 I’m looking for a more permanent solution
