2012 Solid Left Turn signal when headlights fully on.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by diamonddaveb, Mar 20, 2015.
  1. diamonddaveb
    diamonddaveb New Member
    NY
    I have searched the Owners Manual, forum and internet for help with this, but I can't come up with a solution. Perhaps I am not using the correct terminology. I also have an ALLDATA DIY subscription on this vehicle, but I could not find any instance of this occurring to be able to troubleshoot. I though that there might have been a light out somewhere.
    Here is my issue: When I turn on my headlights, the left turn signal arrow on the dash is solid. All left signal lights on the vehicle are also solid. they stay solid the entire time that my lights are on, even with out trying to engage the left turn signal. If I go to engage the left turn signal, they stay solid. The right side appears to be working just fine.
    When my lights are off or when I engage the daytime running lights, the turn signal indicator light on the dash is not solid and neither are my left lamps. When I engage the left signal, all lights appear to work just fine. The only way that I know that something is up is that my dash lights blink off and on while the left turn signal is engaged.
    Has anyone else experienced this?
    #1 diamonddaveb, Mar 20, 2015
  2. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    My educated guess would be a short near or at the turn signal / headlight switch stalk.
    diamonddaveb likes this.
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Or a missing ground for the left side turn signal lights.
    Corroded connectors can cause strange stuff to happen too.
    While any competent shop should be able to fix this, my bet is that most won't be able to quickly or easily.
    That includes your Toyota dealer; unless they have a mechanic on staff that was trained and experienced before cars had "computers".
