2012 Toyota Prius Check hybrid system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Joshfrom407, Feb 23, 2018.
  1. Jakemathews
    Jakemathews New Member
    22
    Buena park ca
    Tried to erase if from snap on scanner and zurich zr13 but nothing lets me clear the code still remains. After all codes are cleared And right away i go back and check the code is still their
  2. Mendel Leisk
    42,364
    Dr Prius can dismiss codes too? There are versions of iPhone or Android. You need an OBD bluetooth adapter as well; Carista works well.
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Stick to non-carista products, monthly subscription fees after the 30 days. Better to save money to get an old version of tech stream w/mini vci on a $50 laptop than monthly subscription fees.
  4. Prodigyplace
    12,720
    11,852
    Central Virginia
    You only do that if you have no ethics regarding improperly licensed software.
  5. Jakemathews
    22
    Buena park ca
    Tried the old tech stream way with a laptop tried to clear it via that but no luck. Wont even clear. Is their any way you guys think the ecu may be bad? I appreciate all the help guys
  6. Mendel Leisk
    42,364
    That's if you're using Carissa App? I've just used it as a hardware interface with dr Prius, just the one-time expenditure for DP.
