2012 toyota prius two at 150k milage
Discussion in 'Gen 3 Prius Main Forum' started by jeseskane, May 9, 2019.
  1. jeseskane
    jeseskane New Member
    Hello everyone,i apologize if i opened this topic on wrong section.
    I just bought a 2012 prius two at 150k milageI know it is actually late to take an advice.Anyways.
    One owner and i found service records on internet in every 5k milage from toyota dealer.
    i was wondering if okay deal for 6000 dollars? or 150k milage too much for it?
    It has a clean interior,and an ok exterior with some marks and dents.
    After 50 milage of drive i seen 68 mpg on car darshboard after i stoped engine,But later when i do short drives to work i realized mpg keep going down,around 47 to 58 mpg,i dont know it that is normal or something wrong with the car.
  2. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    It will settle in at or around 50 mpg, depending on how you drive it.
    As far as price, if you put your actual location in your profile, it’s easier to judge, or you can do it yourself looking at ads for other Prii (plural for Prius) and seeing how the price you paid compares to them.
    Now, since it is yours, watch the coolant level for a few days. A lot of Prii in this mileage range start loosing coolant. If yours doesn’t, then that’s a plus. Find a mechanic that can do a deep clean on the EGR Cooler and intake manifold soon. While it’s apart, get the plugs changed. Change the oil, and maybe even send a sample to Blackstone Labs. They will send you a kit to send them the oil for free. You pay for them to analyze it. They can detect bearing material, unburned fuel, and even antifreeze in it. That will give you an idea of the overall health “right now” of the car.
    And finally, don’t be afraid to ask questions. The only dumb one is the the one you don’t ask, generally speaking.
    WilDavis, jeseskane and Mendel Leisk like this.
    52,837
    congrats and welcome, all the best!(y)
    jeseskane likes this.
  4. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    I’d guess the price paid is okay IF the engine is in decent shape. I’d monitor the oil level and coolant level carefully and often. I’d also verify Toyota maintenance schedule has been followed AND, if not done yet, I’d clean the EGR circuit thoroughly.
  5. Mendel Leisk
    42,332
    Since it hasn't been mentioned, other maintenance items to consider:
    1. Brake inspection. A full, pull the calipers off inspection, clean and relube of the pads and caliper pins. Toyota USA recommends tri-yearly or 30K miles. ($300~400).
    2. Brake fluid replacement. Toyota USA says nothing; Toyota CDN recommends tri-yearly or 48K kms. ($125~)
    3. Transaxle fluid replacement. Toyota USA and CDN both say the fluid is lifetime, but highly worthwhile to change, regardless. ($100 max) (Use Toyota ATF WS only)
    I'd second the EGR and Intake Manifold cleanings, they're necessity. Consider Oil Catch Can install too.
    (Watch @NutzAboutBolts videos, if you're inclined to DIY, or just to see what's involved. There's a thread pinned at top of 3rd gen maintenance forum, linking them.)
    NutzAboutBolts and jeseskane like this.
  6. jeseskane
    Coolent level is LOW,actually it is first thing took my attention...Can i put extra coolent to make it full ?i have extra toyota coolent in my home
    Or should i replace all of it at once?
    Yes i seen toyota service records online,and seems like they did it in every 5k miles.
    Btw car has brand new tires,idk if good sign or bad.Also rotors seems in very good shape.
    Thanks for replies...
    Edit : i did battery check with my scanner and it showed %63 batter life left.
    #6 jeseskane, May 9, 2019
  7. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    You will usually get lower mpg on your shorter drives to work. You're probably starting with a cold engine and won't drive long enough to get the car fully warmed up. Anything at 50 mpg or higher over a full tankful will be a good sign.
    When I first joined this board, I used bwilson's chart, here, as a resource on increasing my fuel economy.
  8. Mendel Leisk
    42,332
    Yeah that should be ok. Is it Toyota Super Long Life Coolant? That would be safest. I found I had to top up both our reservoirs a few years back (they both got down to the low mark), and it's been stable since.
    That's the 12 volt battery? What scanner? Some sort of electronic load tester? I've used a Solar BA5, which tests CCA, compares to spec'd, gives a verdict. If you leave the hood ajar, check the voltage with a multimeter first thing in the morning, that would be a good data point to post too.
  9. jeseskane
    I tested it with an obd2 scanner and android App.
    I tested prius battery,the big one in trunk.
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Bought mine the same way, was an inch below the full mark. Poured more in and stayed that way, got lucky. If it was truly serviced every 5000 mi then wait for the next coolant Change interval.
    Which scanner was used and which battery was tested at 63%?
    RMB likes this.
  11. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Just make sure you drive at least 20 min or 5 mi minimum commute or each drive. Anything shorter you have mpgs in the 30s. A lady once posted that she had awful mpgs, turns out she lives in a town that had hill grades in all angles. I’ve driven through that town and boy it trashed my tank overall mpgs.
    RMB and jeseskane like this.
  12. jeseskane
    I think i used BAFX or something like that.
    RMB and Mendel Leisk like this.
  13. E46Prius
    E46Prius Active Member
    314
    220
    Costa Mesa
    I changed the transaxle oil on my 2015 CT200h F Sport at 40k miles. Was really dark. Cost me about $43 to do myself using Toyota WS.
  14. jeseskane
    I have a little update about car
    Today i bring car to a mechanic and he told me that engine head gasket replaced before and i asked if there is any problem with the engine,and he said no it look fine.
    Should i sell the car or keep it since head gasket replaced?
  15. bisco
    52,837
    keep it, you're all good now for another 150k
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Did he pull the information out of the air? How was this confirm on mechanics end? Some will jus say that so you lll keep the car knowing that if anything happens next, you’ll return right to him and then will keep trying to fix something that may not even be the permanent fix. Sounds jaded but this stuff happens
    #16 Grit, May 16, 2019
    Raytheeagle and jeseskane like this.
  17. jeseskane
    I seen something off on top of engine,some stuff look like made by cotton or something not sure how ot describe it,so i worried about it and brought car to a mechanic and asked him if that stuff is normal on top of engine?
    And he said that yes that is totally fine they put that stuff there after they replace head gasket.
    Then i asked do you think that head gasket replaced before?
    And he said yes,and since there is no leak you are good.
  18. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Did he do a compression test to confirm no leaks?
  19. jeseskane
    Nope only visual test.But when he was looking at engine car was on.
  20. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Just a visual inspection will not be accurate. At the very least a compression or leak down test is going to be needed.
    Grit and jeseskane like this.
