2012 toyota prius two at 150k milage
Discussion in 'Gen 3 Prius Main Forum' started by jeseskane, May 9, 2019.
  1. jeseskane
    jeseskane New Member
    And i have to mention,whole engine look brand new.i mean every single part of it,at first i thought they cleaned it very well,but now i am not sure how much of it new.
    At this point i am very confused if i can trust this vehicle...
    So far i made 300+ miles with it.
    Full tank seems like 53 mpg.
    It drives really good and quiet,But a very low frequency sound taking my attention,it is a noise that very hard to hear,idk what is that.
    And last thing it accelerate very aggressive.
    #21 jeseskane, May 16, 2019
    51,669
    if it is your first hybrid, most of the different sounds you hear will be normal.
  3. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Even the low frequency? :eek:
  4. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    If the Head Gasket was recently replaced and done properly, you should see new gaskets on the cylinder head, intake manifold, exhaust manifold and valve cover. The mechanic probably saw the corners of the new gaskets. The RTV on the timing cover will also look different than factory.
    CR94, jeseskane and Raytheeagle like this.
