2012 Toyota timing chain
Discussion in 'Gen 3 Prius Main Forum' started by James D, Mar 26, 2022.
Tags:
  1. James D
    James D New Member
    Buckeye
    My 2012 Toyota Prius Camshaft will not make a complete
    turn along with the crankshaft. I set the timing marks and it turns 1/4 of the way and then it stops. The cylinder head is rebuilt so I don't know if there is a valve problem since it is a rebuilt head.
  2. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    Then it stops like something’s hitting . So you are re assembling an engine assy . The upper end . Bottom end left alone? Everything has to be on marks Assembled in order correctly. was it put up on timing marks at disassembly? Have you watched any videos of head job on 2z Prius? Or what do you think has happened ?
