2012 txv valve location
Discussion in 'Gen 3 Prius Main Forum' started by blueberryprius, Jun 19, 2022.
  1. blueberryprius
    blueberryprius New Member
    Greetings,
    Mechanic states compressor is done. Was quoted 2700 to replace it and txv. I declined, bought used compressor, gauges, vacuum pump, etc to change it myself. Comprssor has some pressure so i feel there is no metal in the system. 75 low and 125 high side psi. Found instructions from Mendel. Txv was recommended to be changed as well but I cannot find a procedure or even a picture of where it is. Does it need to be changed? Could anyone provide guidance on where it is and how to get to it? 164000 miles on the clock.
    #1 blueberryprius, Jun 19, 2022
  2. PriusCamper
    PriusCamper Senior Member
    13,201
    5,346
    Pacific Northwest, USA
    If it ain't broke... Here at PriusChat we like to argue about this particular ideology alot. :)
  3. blueberryprius
    I appreciate your post. After reading your recommendation and consulting a family member with years of commercial a/c experience we decided to change the compressor and see what happens. Have a great day!
    on mobile, may have typos
