2012 v (lowercase v) lost power and couldn't start
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by weidake, Oct 19, 2015.
  1. weidake
    weidake Junior Member
    63
    Houston TX
    I was driving on the highway, and suddenly my v (lowercase v for the Prius v wagon) lost power and all kind of lights start flashing on the dash. Could not start the car afterwords and had to have her towed to my local dealership. Anyone had similar experimence?
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Yes, it sounds similar to an inverter or coolant pump failure.
    If it's a coolant pump failure, it will most likely be drivable after sitting a while, after the inverter cools down. Also, you can check for coolant circulation/turbulence in the coolant reservoir when in Ready Mode.
    If it's an inverter failure, it's more serious, but it is fully covered under warranty.
    weidake likes this.
  3. Air_Boss
    Air_Boss Senior Member
    4,226
    1,188
    New Yawk
    Have you had the MGU/inverter firmware recall done?
  4. weidake
    63
    Houston TX
    I don't remember. I had an oil change 2 weeks ago at a Toyota dealership and they said everything looked good and they never mentioned to me about an outstanding recall.
    My car wouldn't go into ready mode when I try to start her.
    I have 80K miles on the clock, inverter is still covered under warranty?
  5. xliderider
    8,140
    3,277
    Honolulu, HI
    80k, yes definitely covered.
    weidake likes this.
  6. weidake
    63
    Houston TX
    That's the best news I've had in the past week:)
    Had 2 of my 3 cars broken down on me in the past 2 weeks.
  7. weidake
    63
    Houston TX
    Problem confirmed. Inverter failure! Covered under powertrain warranty!
    Thanks all!
    xliderider and bisco like this.
