2012 Vehicle Customization Options?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by neilw, Apr 13, 2012.
  1. neilw
    neilw Junior Member
    42
    The customization manual for the 2012 Prius (just got mine) lists a whole pile of (allegedly) user-settable options. Some, like the backup beeper, are clearly listed as "dealer-settable only", but most are checked in the middle column, which means "settable via Navigation system". When I go to the Setup/Vehicle page, though, there are only about half a dozen settings; most of the ones from the manual are not there. Example: Smart Key System. I would like all doors to unlock when the driver's door is unlocked via the smart key.
    Anyone know what gives? Should I be allowed to set this stuff or not? Is there some other way to access these settings?
  2. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    Re: 2012 Viehicle Customization Options?
    There's a page number listed for each item on the list. for example, Smart Key System in my manual says "Page 61." Try looking on that page and see if it gives you the answer that you need.
  3. neilw
    neilw Junior Member
    42
    Ah, you are correct. I was fooled by the implication that the settings were settable in the touch display, and thought the page number references showed how to use the feature, not how to customize. That was true, actually, but the customization instructions are nearby (page 70, in the case mentioned above).
    I don't know why they don't put everything into the touch display, but whatever, as long as I can make the changes I'm happy.
    I am interested in folks mentioning the "warning noise" the car makes at slow speeds in all-electric mode. My car makes no such noise...
    52,694
    i took a plugin for a test drive today and couldn't hear anything driving slowly thru the parking lot with the windows down.
  5. d2mini
    d2mini Active Member
    519
    106
    Houston
    It's quiet but it sounds like a space ship. Let someone else drive it, or drive into your garage with the windows down.
  6. neilw
    neilw Junior Member
    42
    Tried it in the garage tonight, and sure enough there it is. Much quieter than I was expecting. Can't hear it when there's any amount of ambient noise outside. Funky!
  7. jabecker
    448
    78
    Portland, Oregon
    When I was driving through a parking lot the other night, a kid turned and stared at my car with a very surprised look in his face. So... I guess other people can hear it. :D
  8. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    My wife and grown kids tell me the noise is there though low. My hearing (child of the 60s loud music) is not what it once was! :D
  9. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    The 2012 manual is less then informative in many cases due to the fact that it's a mashup of the 2010-2011 manual and includes some of the changes made for the 2012 models. It's almost misinformation in some cases when referring to the cars electronics systems.
    You can enable "all doors unlock via SKS" by entering the correct sequence one time into the fob when in/near the car.
    You can disable two-press unlock via the car's infotainment system. This will let you unlock all doors by pressing the unlock button on the remote fob just one time.
    You can disable the constant in-car reverse gear beep with the ELM tool and a laptop.
    You can disable the constant in-car passenger seat-belt unbuckled beep with the ELM tool and a laptop.
    You can not disable the vehicle proximity system via software at this time.
