2012 w Nav/Entune Suddenly "System Not Installed?"
Discussion in 'Gen 3 Prius Audio and Electronics' started by Midpack, Jun 23, 2017.
  1. Midpack
    Midpack Member
    461
    43
    Chicagoland
    The Display Audio w Nav & Entune has worked fine for over 5 years. Yesterday when I pushed the "Apps" button, I just get an overlay that says "System Not Installed." The display works, radio is fine and so are all the "Car" info screens, but no apps. And when I went to make a call, it says I don't have any phones paired, even though I've used bluetooth phone hundreds of times. And I plugged my phone into the USB port to charge and hoping it might wake up the apps - no luck, and it didn't even charge the phone (so port is disabled?).
    No one has done and work on the car and nothing was changed - first thing everyone asks.
    I called the local dealer and (of course) they've never heard of the problem, and didn't have any openings until next week. I called Toyota USA tech service and they were going to suggest I reinstall Entune but said I can't if the USB port isn't working. I was going to try it anyway, but I could not find a download file online??? So they said take it to the dealer...
    I found several other owners who've had the problem but few answers. One said they were told they needed a new "control box" at $1600.
    Anyone here who can shed any light on this issue?
  2. ChapmanF
    19,008
    Was "Display Audio w/ Nav and Entune" one of the options that involved an "extension box" mounted just below the headunit itself? You can check in the wiring diagram (or just look).
    I wonder if maybe that box has joined the choir invisible.
    -Chap
  3. Robert Morgan
    Robert Morgan New Member
    St. Louis, MO, USA
    Having this same exact issue on my 2012 Prius. Did you have any findings you can share here?
    Thanks,
    Rob
