2013 1.8l Prius cylinder head gasket replacement
Discussion in 'Gen 3 Prius Technical Discussion' started by donzoh1, Jan 19, 2019.
  1. Mendel Leisk
    41,463
    Here's @Ragingfit's odyssey:
    Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v | PriusChat
    Prius v is getting the transplant, but it's the same process; he previously did the same transplant with a regular 3rd gen Prius.
  2. donzoh1
    donzoh1 Active Member
    448
    153
    Lenexa, KS
    Got the Prius back together and drove it a day or two. No warning lights, no funny noises, no smoke, no obvious leaks. My friend drove it and got it up to 100 mph so I'm thinking it's where it needs to be. I'm guessing the compression issue has something to do with the coolant leak that resulted from the root problem in the engine...perhaps from coolant accumulating in a cylinder. It seems that it's close enough to run well, at least for now.
    FnRedPrius and Raytheeagle like this.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Awesome, I am happy to hear that the car is running again. Do you have any plans to perform another compression test?
    Raytheeagle likes this.
  4. donzoh1
    448
    153
    Lenexa, KS
    I'm not planning any more compression tests. I feel very confident that whatever compression issue remains is lower end, not cylinder head, based on the leakdown test noises and the only way that would be fixed is engine replacement or a complete rebuild.
  5. johnnychimpo
    johnnychimpo Active Member
    514
    112
    Monterey
    will read the entire thread later but what was the outcome did you have a bent rod? where did the coolant end up getting into the oil?
  6. donzoh1
    448
    153
    Lenexa, KS
    It wound up as a bent rod that eventually broke, resulting in immediate and total ICE failure. The shiny opposing walls of the affected cylinder were symptomatic of that but I didn't realize it before putting the head back on. Coolant was getting into the affected cylinder and while engine cooled after shutdown, coolant would fill the space above the piston. This would be particularly nasty if the piston was moving up on compression at shutdown. As I wrote previously, another indication of the problem was excessive compression in the affected cylinder as well.
    MikeFixes and Mendel Leisk like this.
  7. Mendel Leisk
    41,463
    “Like” is not the word for it, but thanks for the update.
