2013 4 performance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Justin Cummings, Aug 29, 2021.
  1. Justin Cummings
    Justin Cummings Junior Member
    Missouri
    Hello everyone. I have a 2013 version 4 and I'm having a problem with my car. The consumption display is showing i'm getting around 30-40 MPG around town. It does have 212K miles. I changed the spark plugs, and air filter and cabin filter today. I also cleaned the EGR pipe with carb\brake cleaner. I don't know what's going on, but I'm worried. Is it the big battery? Is it the intake manifold\EGR valve? Any ideas??
  2. saltdiscus
    saltdiscus Member
    198
    89
    US
    Is your AC on when driving?
    52,841
    i would clean the whole egr circuit, but that probably isn't the problem. has anything changed with your driving or the car like short trips or new tires?
    how is the 12v health?
    what mpg are you used to seeing?
    best to keep track of mpg by the tankful, and not the consumption screen
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    How is it running and idling, is it running rough, idle shaky? Is it misfiring?
    That's a big loss in mpg, you'd think you're only running on 3 cylinders to get that kind of fuel economy.
    Maybe your brakes are dragging/is there an anchor chained to your bumper that you are not aware of?
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_O
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    We can rule out brakes dragging or new tires since it wasn’t mentioned :LOL:
  7. Mendel Leisk
    42,341
    You just cleaned the pipe? C'mon...
    Look up EGR cleaning in my signature.
  8. bisco
    52,841
    it may not be the problem, but it is a problem
  9. Justin Cummings
    Missouri
    Yes, but it does it without too
  10. bisco
    52,841
    that's not good
