2013 Auris TS. What to look out for?
Discussion in 'Toyota Hybrids and EVs' started by Bibster, Feb 8, 2020.
  1. Bibster
    Bibster Junior Member
    28
    România
    Hey guys. I'm the proud owner of a Oct 2013 Auris and loving it so far. It has 100.000 miles on it and looking in good shape.
    What should I do as basic maintenance? Should I be worried of the engine problems that the early gen 3 Prii had or were they solved by 2014? Should I do an EGR cleaning? What else can I do to Keep the ICE in top shape? Any advice welcome.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Is the AURIS a HYBRID? If not, the engine is significantly different (it would be OTTO cycle, not Atkinson)
  3. Bibster
    28
    România
    Forgot to mention, it's hybrid, yes. The hybrid system is still under warranty so my main concern is the ICE. (Tbh not sure if the warranty covers only the battery or the entire hybrid system)
    52,891
    congrats!
    if it has an egr, you want to follow the cleaning proceedure and oil catch can install at @NutzAboutBolts
    youtube channel
    Bibster and NutzAboutBolts like this.
  5. Bibster
    28
    România
    Thanks, that's exactly what I'll do when it reaches 100k miles (hasn't reached it yet). Another thing: is it necessary to change the CVT oil? If so, when? I can't be sure whether it has ever been changed or not so far. Thanks!
  6. qettyz
    qettyz Active Member
    181
    208
    Finland
    Auris 2013 has Prius Gen3 tech. All the same, but HV battery is different.
    You can find lots of stuff from Prius Gen3 forum.
  7. Trollbait
    12,832
    The CVT fluid should be changed at some point. For automatics that claim 'lifetime' service, I change at 100k miles.
  8. bisco
    52,891
    Many have tested the cvt fluid and recommend changing it, but no agreement on intervals.
    Do it now and read up on it for the future
  9. Bibster
    28
    România
    Thanks for the info! Will do it.
