2013 c1 steering wheel controls
Discussion in 'Prius c Audio and Electronics' started by Teddy Ngo, Mar 28, 2020.
  1. Teddy Ngo
    Teddy Ngo Junior Member
    40
    16
    Mission Viejo, California
    I'm going to replace the stock headunit, and want to keep the steering wheel controls. Does the Metra 70-8114 adaptor work for our cars?
    Anything else i should know about before i start taking the car apart and replace the headunit?
  2. Leadfoot J. McCoalroller
    8,288
    7,801
    Pennsylvania
    2018 Prius c
    Wrong harness. You'll want the Metra AX-TOY28SWC instead. It looks nearly the same but has the updated 28-pin connector on the car end. The one you linked appears to be for the older big-body Prius.
    You should be aware that both the harness you listed and the one I have listed above are not complete solutions- they are intended to be used in conjunction with the Axxess ASWC-1 translator box, sold separately.
    Good luck!
  3. Teddy Ngo
    40
    16
    Yup i bought the rest of the adaptors and controls already.
    Thanks
