2013 Charging
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Vincent Schodolski, May 23, 2013.
  1. Vincent Schodolski
    Vincent Schodolski New Member
    I just purchased a 2013 Prius Plugin and am seeking advice about the merits of charging at 110, 220 and 240 volts. Pros and Cons welcome.
    Vince
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Slower charging, faster charging. 3 hours vs 1.5 hours.
    No added costs, added costs. Car comes with a 120 evse vs buying and installing a 240 evse which could run several hundred dollars to over a thousand dollars.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    If 3 hours charge is too long for you, pay about $1k to be able to charge in 1.5 hours with 240v.
    240v L2 charge is a few percentage more efficient. It sure does not make economic sense.
    Hi Burrito! likes this.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  5. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Would recommend a 240V charging station only if cost is not a big issue and you could really use 1.5 hour charges or planning to get another car in the near future with a much bigger battery that could benefit from 240V. Otherwise, consider waiting a few years. Costs are already coming down from the pretty steep current prices of the 240V charging stations.
  6. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    Vince
    I have had 240V charging since my PIP was new on 3/28/12. I agree that it is not economical if that is a controlling concern. But it is handy to have a charge done in an hour when I come home and realize that I have another trip the same day. That matters only if you care about not running the ICE. If the next trip is too snort to adequately warm up the ICE, the option to get by with just EV is desirable.
    A non economic consideration is that with 240 charging, I leave the factory charge cord in the car for emergency needs and the 240 charger set up to plug right in for charging. It couldn't be more handy.
    To me it boils down to what is important (or not important) to you. I know I could live without 240V charging but I like it.
  7. bisco
    52,645
    best thing to do is use the 120v for awhile to see if the 240v would improve your situation in any way. i got one so i could leave the 120 in the car to charge at work. it's also nice whe your doing a bunch of errands from home and you keep coming back to top it up. the longer you wait, the cheaper they get!
  8. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Something else to consider is that if you are in California or some place with high electricity rates, the shorter charge time of an L2 charge might not be beneficial if you have to charge overnight to take advantage of lower rates.
    I no longer charge during daylight hours because it can cost me up to $0.50/kWh towards the end of my billing cycle. That's the equivalent of $7.50/gallon of gas. I only plug in overnight when it is $0.06 - $0.16/kWh. 1.5 or 3 hour charge time is inconsequential.
  9. Jim Gallagher
    Jim Gallagher New Member
    2013 Prius Plug-in
    I just ordered the 16amp Bosch unit for $450. Between the 30% federal tax credit and the 50% NYS tax credit, it was worth it. Plus my friend is hooking up the 220v outlet in my garage at no cost.
  10. SJ PiP
    SJ PiP Member
    190
    35
    mmmodem likes this.
  11. El Dobro
    El Dobro A Member
    7,102
    3,282
    I pretty much do the same thing, 110 at work and when I get home, the 220 charger, so the car's ready when I have to do some running around. The car's charged by the time I'm ready to run.
