2013 dead battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Laurie Tilson, Apr 20, 2021.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    The 12 V battery in a Prius follows the same "rules" as one in any other vehicle.
    What's with all of that white space in the middle of your post ?
    Something else "anal" ?? :ROFLMAO:
  2. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes but that doesn't mean that 60% is all it is capable of.
    Charge it up good and then let it sit for 24 hours and take another reading.
    Given your reported usage, connecting a tender once a month (at least) for 24 hours would be good.
    Allowing it to sit at 60% for long periods will cause it to age prematurely.
  3. sam spade 2
    7,035
    2,804
    2017 Prius c
    Doing that very often causes you to miss the early warning signs of the battery going bad.
    It will ensure that it starts fine in your garage every time.
    It also makes it likely that it will finally "die" some place ELSE, which is a lot less convenient.
  4. Mendel Leisk
    42,250
    I’m using a CTEK 4.3 charger. According to manufacturer’s FAQ #1 it’s ok.
    FAQ CTEK Consumer
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    You aren't understanding what I am trying to tell you.
    It makes NO difference what tender you use.
    Having it on a tender ALL THE TIME will ensure that it has enough charge to make the vehicle run every time you disconnect the tender and start it.
    BUT......at some point in time, the battery will fail and have a severe loss of capacity. Having it connected to a tender will cover up that event in the convenient environment of your garage.......usually......and the total failure will occur some place ELSE at the other end of your trip.
    If you still don't understand, then just stop because I don't think I can explain it any better.
    I just changed the battery in my Spyder last week......and noticed that the owners manual recommends connecting a tender type charger for 24 hours any time it will (or has) sit unused for 2 weeks or more.
  6. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    So. What you SEEM to be saying: even GOOD batteries (which we've started with...we people who use battery maintainers because we don't use the car all that much) will eventually fail, even if they are kept charged?
  7. Mendel Leisk
    42,250
    Yeah I’m a lost cause Sam.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes. Absolutely.
    Taking good care of them will make them last longer........but not forever.
    A good AGM battery in a vehicle that is driven often OR kept charged by periodic use of a small charger or tender might be expected to last up to 7 years, sometimes a bit more.....but living in a VERY hot climate can reduce that some.
    One that is not driven often and otherwise neglected can be expected to last maybe 4 or 5 years; sometimes less.
  9. Mendel Leisk
    42,250
    Five and a half years installed optima yellow top, measurements in March (cold crank amps and volts):
    560E738E-0E77-40BD-88E0-218ADBFA658C.jpeg 3C190BCC-CE15-43A4-A2A6-B512D3EF9D25.jpeg
    Raytheeagle likes this.
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    Well unless your magic meter is putting a significant load on it when measuring volts......that really isn't that good for an AGM.
    Under no load, it should be at least 12.8 or 12.9 if really healthy and fully charged.
    I just got a new one for my motorcycle last week and the construction must have been improved a little because it reads 13.1 fully charged with no load after sitting overnight.
  11. Laurie Tilson
    Laurie Tilson New Member
    Rochester, ny
    No, the daughters device was not connected to obdll. We had no idea it was there in the first place. We bought it second hand from a Toyota dealer out of state, flat bedded to NY . Our Toyota tech. Only told us it was there in its third visit. The first visit was it's inspection.
    I really don't quite get who or why the one device was still on there.
  12. rjparker
    rjparker Tu Humilde Sirviente
    10,985
    6,886
    Texas Hill Country
    They are tracking and speed logging devices sometimes used by insurance companies to lower your rates. Sometimes people use them to track their kids or spouse. The obd2 connector is also where any mechanic would check for trouble codes and live data. So your first $100 diagnostic mechanic either did nothing or was clueless about what could be eating power.
  13. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    transitioning to Pete buttigig’s miles annually driven tax.
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    Are we suddenly talking about a different device now ?
    OK but it was getting power from the car somehow......right ?
    And likely was "hot" all the time.
    Which would discharge the battery while the car is not running.
    #74 sam spade 2, Apr 26, 2021
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    dupe deleted
