2013 FRS wheels on Prius prime
Discussion in 'Prime Accessories and Modifications' started by Nguyenx49, Sep 17, 2018.
  1. Nguyenx49
    Nguyenx49 New Member
    Bay Area
    Hello guys and gals,
    I got a great deal on a set of FRS wheels and I have been searching the forums. I only found these threads for the gen 3 Prius. I want to know if anyone with the prime got the FRS wheels?
    From what I know after researching that the FRS wheels offset is 48mm and oem prime wheels are 40mm.
    For gen 3 Prius, members need to get 3mm spacers, 56.1mm to 54.1 hub rings and new lugs. Is that the same for the Prime? If not, please let me know what I will need to make this wheels work.
    Thanks in advance!
  2. Nguyenx49
    Bay Area
    Anyone know?
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I don't know the answer to your specific question, but have you looked at this thread? Aftermarket Wheel Fitment Guidelines | PriusChat
    Sorry for not being able to help you much, but welcome to Priuschat.
  4. Nguyenx49
    Bay Area
    Thanks! Yes I did look at the thread but nobody mention the FRS on the prime. Thanks again for the respond!
  5. Salamander_King
    11,024
    8,978
    New England
    Sorry I couldn't be more help. I hope someone familiar with the subject will chime in. Good luck.
  6. burnout8488
    burnout8488 Member
    124
    81
    Endwell, NY
    Why not just research what the Prime's hub size is and buy the rings accordingly? You already know what the hub of the FRS wheels are, stated above. Seems like the figures are there, you just have some googling to do.
  7. ConfusedBirdie
    44
    34
    Did you ever mount the wheels on your prime? I put some on my 2017 and am curious to your results. Mine look amazing but the gas mileage has tanked. ~ 20%
    I’m wondering if something is wrong.
  8. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    yes it would be the same. Just confirm the hub rings I forget what size they are. I got a set in Enkei wheels for my prime
  9. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    Here’s the fitment
  10. fusion
    fusion Junior Member
    26
    San Francisco
    2019 Prius Prime
    You going to keep those lower profile tires or go back to stock profile later?
