2013 Gen 3 90k. Brake trouble lights.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by chuckiechan, Jun 27, 2022.
Tags:
  1. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    I had an earlier post where brakes were acting like a warped rotor. Didn’t diagnose. now I have trouble lights kazoo and something is and feels obviously wrong.
    I see no obvious signs of fluid leakage on the inner rims. Reservoir is slightly below “add”,
    Photos attached.
    I can’t do much until tomorrow & I’ll pull all four tires & put on jack stands. I won’t dissemble without advise & I caught the warning about disconnecting the batt before going too far.
    Thanks in advance.
  2. JC91006
    16,937
    8,647
    Well your fluid is very low so you might want to see if your brake pads are down to ZERO. That would be a good reason why the brake fluid is that low.
    ASRDogman likes this.
  3. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Would it suck air at that point? The machinery running the brakes sounds and feels funny.
    I hope to take the wheels off tonight or tomorrow.
  4. JC91006
    16,937
    8,647
    You can potentially run into issues when the brake fluid is below the "add" line. But looking at your picture, I don't think that level is low enough to cause a problem. However, when you drive up or down an incline, the level may change and that's why there is an "add" line to prevent issues.
    These cars also have issues with the brake actuator/booster ($2000+ repair), so hopefully that's not what you're experiencing. If you are having problems with that, then pray that you have less than 150k miles on your car. Toyota has an extended warranty for this repair, up to 10 years and 150k miles.
  5. bisco
    52,877
    whee there are lights, there are codes. don't bother with all the phisical labor before starting the mental part.
  6. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    I think I will pull the wheels off tomorrow and do a visual, and hope the dealer honors it. If everything is dry it has to be the booster right. Pushing down the brake when the engine is off kind of makes a “whoosh” sound.
  7. JC91006
    16,937
    8,647
    If you have less than 150k miles and the codes point to the brake booster, then you pretty much hit the lottery and get a free repair.
  8. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    As you can see I have ABS light on, auto track* (car with squiggle lines) and “Brake”.
    *which I don’t even know if I have.
    (my pit crew is OTW.)
    About that booster sound?
  9. bisco
    52,877
    dealer will read the codes, charge you if it's not covered, free if it is. don't bring it in with low brake fluid
  10. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Is it DOT 3 or 4?
  11. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
  12. JC91006
    16,937
    8,647
    You can use either 3 or 4. Dot 3 is what came with the car.
    If you're going to fill it, just fill to the middle of the "add and full" marks. Don't fill all the way to the top. As you change your brake pads, that fluid will need somewhere to go
  13. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Don't make this more difficult than it is. Just add fluid. It has a level gauge. Just put fluid men
  14. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    I read the codes, see attached. ABS Code C 1391.
    But now all of a sudden the problem went away. Maybe with the photo of the dash and the code the dealer my do it under warranty… or is that like finding a unicorn in my back yard?
    #14 chuckiechan, Jun 27, 2022
  15. JC91006
    16,937
    8,647
    Well with that code, you get a free replacement. Whatever you do now, don't erase the codes. They are stored and Toyota Techs are retrieve them.....unless you delete it
    douglasjre likes this.
  16. douglasjre
    2,250
    751
    Null, NL
    Is the letter c in front of 1391? You have to be complete and thorough in what you provide for information. C1391 by my records is a bad accumulator. 10 years or 150,000 mi is the max on the TSB that will replace the booster accumulator and ABS controller. Are there any other codes I didn't think to ask about?
  17. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    It is C 1391… don’t know how I fat fingered that! .
  18. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    6/28 update
    The service person found the extended warranty, and I’m bringing it in Thursday.
    I’ll follow up when it is resolved. Thanks for all your help. I wound not have known!
    douglasjre and bisco like this.
  19. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Good news: They accepted the repair. Bad news: parts are two + weeks out. I prefer not to drive and cause an accident. Karma’s radar knows just when to fail!
  20. bisco
    52,877
    a lot of people are waiting. toyota should be paying for rentals as well.
