2013 Import Prius all electrics just turn off when parked
Discussion in 'Prius c Main Forum' started by enginestarter, Apr 30, 2020.
  1. enginestarter
    enginestarter Junior Member
    66
    UK
    Active
    I'm asking for someone else.
    They have a 2013 Prius C - it's an import car.
    Well looked after and serviced and has run reliably for a 2 years with no problems.
    Recently, the car when parked will JUST turn off.
    Park the car over night.
    Come back in the morning... and it just won't turn on.
    Pressing the key just won't respond.
    You have to use the manual key to get in.
    Then... he says he has to open the car door and bang close the door with great force... then the car will turn on all of a sudden.
    I've suggested to him that the key fob battery simply needs changing.
    He says it's been replaced recently - in the last 12 months with good quality batteries (he says). He has 2 keys, both have the problem.
    Shutting the door with great force makes no sense at all to me
    I still think it's the key fob. I think he should try new batteries before doing anything else?
    Toyota dealers won't touch because it's an import.
    Any ideas?
    Thanks.
  2. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Has the 12v battery been replaced? If not, start with that.
    AlphaFox likes this.
    52,804
    loose connection somewhere. start with the battery posts and the negative to ground connection.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Sure it does. IF the main problem is a loose battery cable.
    Which the reported symptoms would suggest.
    AND....if that is the original 7 year old battery, it is needing to be changed too.
  5. enginestarter
    66
    UK
    Active
    Thanks for the replies guys.
    I'll pass on the messages to the owner.
    Surely if a loose connection, then car should suddenly come to a stop randomly?
    ALSO if no luck self diagnosing... Where could the car be taken? A general mechanic or someone specialising in electrics for cars? (Wasn't sure if this existed)
    The car is in North London. Just thought I would mention incase anyone could recommend somewhere nearby.
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    No not necessarily.
    Once the car is running, it makes it's own 12 V power and with a lot of models the battery doesn't really have to be there at that point.
    And the obvious answer for "where to take it" is a Toyota dealer.
  7. enginestarter
    66
    UK
    Active
    Just saw an old question I asked.
    Problem got solved.
    It turned out that there was a wire loose near the battery.
    @sam spade 2 - you were right. The advice was really helpful.
    As mentioned in the post, they said that because it was an import, they didn't want to touch.
