2013 Persona Project..
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Xterra72, Oct 29, 2014.
  1. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    Just put a charger on it for at least 8 hours, at 4 amps....
    That's they battery everyone is complaining about, at least on here.
    They're made a lot cheaper then the yused to be. And it cost more.
  2. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    Which battery is everyone complaining about?
    The link I shared with the Optiima battery or the oem truestart battery (interstate)?
  3. ASRDogman
    8,066
    4,089
    Optima....
    Burna J likes this.
  4. Xterra72
    1,437
    1,684
    Oh, didn’t realize there were issues with the Optima battery either. Thought it would be superior compared to the oem battery. Thanks for the heads up.
    The original oem 12 volt battery that came with my car was better than the Truestart battery I have now.
    it lasted 7 years before I replaced it and never drained out on me.
  5. Mendel Leisk
    42,352
    They used to be Yuasa. :)
  6. Ryan Will
    Ryan Will Member
    68
    43
    Southern California
    Wonder when that changed? My Truestart battery I bought about a year ago is a Yuasa one. Maybe I lucked out?
  7. Mendel Leisk
    42,352
    I think they still are; I was just ribbing @ASRDogman
    Ryan Will likes this.
  8. Xterra72
    1,437
    1,684
    I believe @ASRDogman was referring to the 12 Volt AGM Optima Battery.
    ASRDogman likes this.
  9. Ryan Will
    Ryan Will Member
    68
    43
    Southern California
    I actually realized that moments after I posted! :)
    Mendel Leisk and Xterra72 like this.
  10. Xterra72
    1,437
    1,684
  11. Xterra72
    1,437
    1,684
    4th of July Special! Got new shoes for the Persona today. Michelin Defender 2!
    These tires should last longer than my Bridgestone Ecopia (only got about 36k miles)!
    I tried to order the Michelin X-Tour A/S 2 but it wasn’t available during the 4th of July Michelin one day sale. (Of course it was available the next day, after the sale was over).
    Spent a bit more on the Michelin Defender 2. Heard a lot of good things about the tires. Looking forward to putting these tires to good use!
  12. Mendel Leisk
    42,352
    That’s 215/45R17? I’m getting out of touch with 17” tire options, but seem to recall defenders were not available (in that size) in past.
  13. Bill Norton
    Bill Norton Senior Member
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Right. The Level 5 wheels and tires.
    I sold mine off and bought the standard 15" Prius wheels so get noticeably better fuel economy.
    Love the head lights!
  14. Xterra72
    1,437
    1,684
    @Mendel Leisk , yes, the tires are 215/45/17.
    Rated at 80k miles. Hoping these lasts longer than my Bridgestones.
    #294 Xterra72, Jul 9, 2024
  15. Mendel Leisk
    42,352
    Persona is regular headlights? Our Canadian Touring has the LED's, and the (useless but pretty) fogs.
    Agree about the tire size, we get slightly better mpg through winter, with 15" Michelin X-Ice, compared to the 17" Primacy MXM4 the rest of year.
    Bill Norton likes this.
  16. Xterra72
    1,437
    1,684
    @Mendel Leisk , Persona have the regular headlights .
    I added a clear 3M film to protect the lense from sun damage. So far, the lenses have stayed clear since the day I purchased the car.
    I also added a darker film to the side amber lights to drown out some of the color.
    Ryan Will and Mendel Leisk like this.
  17. AzusaPrius
    AzusaPrius Senior Member
    2,257
    945
    I hated the amber corners too and was so glad I got a good deal on offerup a while ago for a pair of JDM headlights.
  18. Bill Norton
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    LED's with Headlight washers !!
    For those times when you're in a Rally on gravel/dirt roads and the guy you're trying to pass is throwing muck on your headlights!!
    Consumer Report rated them at the top of the list in their testing!!
    The low beam pattern is perfect and the high beams add a lot.
    Anything else on a Gen 3 is the 'cheapest kind', no matter how much 'Makeup' you put on them.
    I agree about the Fog Lights. It's hard to see their pattern on the ground in front of the car. I wish I could use them as DRL's alone.
    Has anyone done an LED replacement for the bulb and got actual better performance from the Fog Lights?
    asusa, I'm considering one of your sponsored 'water injection systems'. What kind of amazing performance increases do you see?
  19. Mendel Leisk
    42,352
    I believe the headlight washers were required because they were concerned the LED's didn't heat up enough to melt snow accumulations. I've used them once or twice, to ensure they work.
  20. Xterra72
    1,437
    1,684
