2013 PiP Base - Check Hybrid System - Error Code P0D67?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by plugin, Jan 16, 2014.
  1. plugin
    plugin New Member
    2013 Prius Plug-in
    When turning on my 2013 PiP Base this morning, I ran into the dreaded "Check Hybrid System. Stop the Vehicle in a safe place" message.
    It seemed to run ok and cycling the power switch 3 times didn't clear the message, so I had it towed to the dealer since I couldn't tell if it was a serious problem that would be made worse by driving or not.
    Well the dealer found a fault code P0D67 detail code 844. They reset it and test-drove it and it seemed fine but they couldn't really tell me what happened other than some problem with the computer and maybe something related to charging??
    Has anyone else run into this? A quick google search shows that this fault code is pretty generic...
    52,863
    yes, i think there is a recent thread. i'll look for it. no luck, could have sworn i saw a thread where someone got this warning lite. anyhoo, i would check the 12v health as a starting point.
  3. lbhbsherman
    lbhbsherman Junior Member
    Sherman, CT
    2015 Prius Plug-in
    Yes, I had that problem early January (not sure where the discussion is either). Tech told us they could find no reason and suggested that we got a bad tank of gas. Car running fine since we got it back.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Searching the DTC codes for my 2010 does not show this code. It may be unique for the PiP or newer models.
  5. 480max
    480max Junior Member
    Phoenix, AZ
    2014 Prius Plug-in
    I just had this issue on my 2014 come up this morning. Just dropped it off to get checked
  6. bisco
    52,863
    any news?
  7. 480max
    Phoenix, AZ
    2014 Prius Plug-in
    Yes. It took 48 hours for them to diagnose and fix it as it had several codes that they had to narrow down. Turns out they needed to replace a part from the EV charger (I can post the exact code and part number if requested). Dealer was really nice, this is only the 2nd PIP they had in for service, so the time to diagnose took much longer. The part was $1,700, but the dealer was only paid for .75 of an hour for install. My 2014 only has 500 miles on it. They said according to Toyota, its only the 3rd time this part has failed so they are sending it back to Japan for testing
  8. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ....figures I am wrong again...I just made the statement in another thread that we have not really had any HV battery related issues on the PiP, with regard to how people in non-PiP roll-out states would fare in the case of an unexpected HV batt problem...do you think this is a PiP specific part?
  9. bisco
    52,863
    yes, it's the charger that takes the power from the wall. i think this might be the second one. there have been a few specific pip issues, but very few.
  10. 480max
    Phoenix, AZ
    2014 Prius Plug-in
    It had to do with a circuit in the battery that was not opening and closing the way it should. I was surprised that they had access to the part so quickly. I know PIP are still hard to find in AZ, so I would assume that the experience in a non pip state would be the same. They can fix it, it will just take them longer to diagnose as they do not see many. They get the code, and have a Toyota hotline to call and they tell the tech what to replace
  11. OnePiP
    OnePiP New Member
    SF Bay Area, CA
    2015 Prius Plug-in
    I seem to be having the exact same issue, what has been the outcome after the replacement?
  12. bisco
    52,863
    assuming no news is good news, i would guess he's up and running without issue.
  13. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Heaven forbid they actually repair something... Always replacing instead.
  14. CharlesH
    2,798
    1,166
    Roseville, CA
    We are talking about complex and specialized computer boards and and such. It really isn't cost effective to have the special test equipment and specially trained technicians at every dealership. Replace the #&!@ thing and ship the defective unit back to a central facility and have the specialists figure out what went wrong and how to correct the design, if necessary.
  15. Rebound
    3,996
    2,645
    Portland, OR
    Luscious Garage repairs Prius' all the time, especially the expensive transaxle.
  16. plugin
    plugin New Member
    2013 Prius Plug-in
    I wrote the initial post for this thread. In my case there was no attempt to replace a part as described above. Instead the dealer couldn't find anything wrong back in January 2014 and I've driven it without any problems since...
  17. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    It seems this issue has reared it head again with the 2015's. At least three new owners reporting this message and most are getting some sort of charger replaced.
  18. bisco
    52,863
    time for nhtsa to get involved...
  19. SmartBattery
    SmartBattery New Member
    Ukraine
    2015 Prius Plug-in
    This code?
    AC/DC (G9090-47040)
  20. bisco
    52,863
    no, not that one, the other one
