2013 PiP Charging cable replacement spec
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Holla, Nov 17, 2021.
  1. Holla
    Holla Junior Member
    Los Angeles
    I need to purchase a charging cable for my 2013 plug in Prius. I charge from home on 110V regular home outlet (NEMA 5-15?). Lots of terminology on charger cables for sale online. Level 2? 1772 or 1773? I was hoping someone might provide me the correct specs or even shoot me a link to the right cable. Thanks in advance!
  2. LeviSmith
    LeviSmith Member
    111
    NY
    Level 1 would be 120V
    Level 2 would be 240V
    1772 is the connector your want.
    There are lots of options depending on what you want for now or allowing for future use and how fast you want to charge, etc.
    But if the only thing you're concerned with is 120V then you just want the cheapest L1 J1772 charger you can find. Probably in the $200-300 range...
  3. Rmay635703
    Rmay635703 Senior Member
    2,705
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    I strongly recommend the $99 DUOSIDA EVSE factory direct
    It’s dual voltage and rated to 16 amps
    Just contact Ms Dream at their factory website there is a walkthrough on the myNissanleaf forums
    Curious what happened to your original Toyota cable?
    bisco and LeviSmith like this.
    52,899
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    First I am going to say if you have any existing 240 outlets in your garage buy an EVSE with that plug. My garage has 6-20 receptacles so mine will be 6-20.
    Secondly there are 120 volt only EVSEs, so you can cheap out and buy one.
    I am going to suggest, however buying one with a 240 volt NEMA 14-50 plug and use a 120 volt adapter (the 120 volt plug is called NEMA 5-15. Some times you see P for plug and R for receptacle)
    Now you are asking "Why have a huge clunky 240 volt cord if I have 120 volts in my garage?"
    If you ever road trip, almost all RV parks have NEMA 14-50 outlets for the RVs, so almost anywhere you go you can plug in and charge in 2 hours.
    PlugShare - Find Electric Vehicle Charging Locations Near You
    Under filters, click J-1772 and NEMA 14-50 and see all your choices. Road trips are when I want fast charging.
    All plug in Prius and almost all RAV4s are limited to 16 Amps, so buying a more powerful EVSE will not speed up a Toyota.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Just go on Facebook marketplace ;).
    I found my spare J1772 cord for $20:).
    It's a Ford cord, but since it is J1772 protocol, it's all good(y).
    Rmay635703 likes this.
