2013 PiP hard to start
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Eric Vasaio, Jun 24, 2019.
Tags:
  1. Eric Vasaio
    Eric Vasaio New Member
    BC, Canada
    2013 Prius Plug-in
    I've got this 2013 PiP a month ago. Recently I found sometimes it's hard to start.
    This happens usually in early morning for the first time start in a day. Press down brake peddle and push Start button, nothing happens, main screen on just like double press Start button but no "Ready" light.
    I have to try and try several times before the "Ready" sign is on and able to drive the vehicle. It never happened if I shut the car off for a short period of time and turn it on again, it happens 90% on the first start in early morning.
    Any comment ? thanks for any input.
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    It sure sounds like a weak, 7 year old 12 volt battery.
  3. Eric Vasaio
    BC, Canada
    2013 Prius Plug-in
    Can't agree more, this is my first guess. Just then I went to check the 12V battery, after parked for 3 hrs, there is 10.15V left. I guess it's too low.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    It’s due to be retired;).
    Good luck and keep us posted (y).
    Eric Vasaio and Data Daedalus like this.
  5. Eric Vasaio
    BC, Canada
    2013 Prius Plug-in
    So, thanks Pluggo and Raytheeagle, I've replaced the ruined 12V battery with a brand new ACDelco AGM battery from Amazon, cost $167.
    It feels very "strong" start now. But what exceed my expectation is, before the 12V battery was replaced, a full charge will show that EV range is 10.2 miles, now after a brand new 12V battery sitting in place, a full charged traction battery will give me a EV range of 12.6 miles. I guess that is because it doesn't have to chip energy trying to charge accessory battery anymore.
    Great! Love PiP!
    bisco and Raytheeagle like this.
  6. bisco
    52,831
    more likely you are getting the factory default after changing the battery. do you have any way to test actual range?
  7. Pluggo
    608
    534
    ...but also you are correct in that your HV battery will not be working so hard trying to keep the new auxiliary battery charged.
  8. bisco
    52,831
    on the plus side, it gets charged along with the hybrid battery every time you plug in.
