2013 Prius 12v battery brand
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JDB, Jul 2, 2017.
Tags:
  1. JDB
    JDB Junior Member
    24
    Have a 2013 Prius and considering to replace the 12v battery ahead of time as I read batteries typically last 4-5 years. I've read about optima, but also some suggest oem, so wanted to get your thoughts based on your experiences. Thanks!
  2. Tomas33
    Tomas33 New Member
    Norway
    Three Touring
    Actually we can recondition batteries using this simple method: ezbatteriesreconditioning,com
    Thank you Gregory ! :)
    52,758
    i find the oem quite vigorous. mine have lasted up to 8 years, so if i had to replace, i'd get another. mine is over 5 years old now and almost like new.
    Neohippy, Tande and Raytheeagle like this.
  4. maurices
    maurices Member
    128
    37
    Sartell, Minnesota
    I too have a 2013 with 45,000 miles. When the 12v battery was going bad, the dash lights came on but not the Ready light indicator. I replaced the battery with a yellow top Optima, highly recommended.
  5. JDB
    JDB Junior Member
    24
    I have over 60,000 miles on mine, mostly highway driving if that matters. I've heard good things about the yellow top Optima and am leaning towards that, but seeing mixed reviews of it on Amazon about the long shelf life of some and failing within a year made me nervous.
  6. bisco
    52,758
    12v longevity is usually time and climate related. but any accidental discharging will shorten life severely.
    optima's were great, then went thru a bad phase, and seem to be better again.
    CNYhybrid likes this.
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    But in my opinion are over-priced and their different design is mostly just a gimmick.
  8. bisco
    52,758
    aren't they cheaper than oem?
  9. Tande
    Tande Active Member
    551
    337
    Mich.
    Yup, Me/Too.....2010....110,000 mi. ......original 12v .....(y)
    bisco and Raytheeagle like this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    2010 Toyota Prius II with 158 k miles on the clock.
    Still on the original 12v battery(y).
    Tande and bisco like this.
  11. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    I would not replace the battery prematurely. Instead I would get a Batteryminder charger that also desulfinates:
    BatteryMINDer Battery Charger/Maintainer/Desulfator System — 12 Volt, 1.5 AMP, Model# 1500 | Battery Maintainers| Northern Tool + Equipment
    I got mine on sale for $30. It will greatly extend the battery life. Install the ring connector under the hood for easy connect/disconnect. It completely rejuvenated a 6 year old battery in my MIL's Mazda 3 that was at 11.8 volts - back up to 12.3 volts steady and holding for as much as a week between driving it.
    I bought a used 2011 Prius with 125,000 miles on it and the original OEM battery seemed weak by measuring the voltage, so I did replace it. I installed the Bosch battery made specifically for the Prius:
    Bosch Premium Performance Battery Group, Size 51 | 647478 | Pep Boys
    It has a 48 month warranty compared to the Optima Yellow Top 36 month warranty. Seriously, though, go for the BatteryMinder first. Keep in mind, the 12v battery does not need high cold cranking amps because it does not turn a starter for the engine, it only boots up computers.
    Kpeeling likes this.
  12. bisco
    52,758
    can't beat a hundred and forty bucks for a prius battery.
    Raytheeagle likes this.
  13. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,784
    Bay Area
    I buy my battery from CostCo :) cheaper than auto stores.
    Neohippy likes this.
  14. Mendel Leisk
    42,244
    @JDB You're in the United States of America I assume?
  15. Sam Spade
    2,036
    1,024
    2017 Prius c
    What exactly does that mean ?
    With the charger still connected ??
    12.3 volts is somewhere around 70% charged.
    If it drops to that within a few hours of disconnecting the charger, you haven't accomplished much and that battery is on it's last legs.
    A healthy battery should hold somewhere around 12.8 for at least 24 hours when in the car......and MUCH longer if disconneced.
  16. NavyLCDR
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    It means 12.3 volts after sitting for a week in a car that gets driven about once per week. It also means the difference between the engine cranking slowly and wondering if it is going to start and the engine cranking normally. It also means getting one or two more years of life out of the battery.
  17. bisco
    52,758
    are we talking about non hybrids here?
  18. Sam Spade
    2,036
    1,024
    2017 Prius c
    It sure sounds like he is NOT talking about a hybrid.......in which the 12 V battery does not "crank" the engine at all.
  19. NavyLCDR
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    That particular battery is in a non - hybrid, however, the Prius 12v battery is still just a lead acid auto battery and the same BatteryMinder will rejuvenate it and keep it healthy longer.
    I just can't see replacing a 2013 battery showing no signs of failure when with a little preventative maintenance it probably has at least a couple more years life in it.
    #19 NavyLCDR, Jul 9, 2017
  20. bisco
    52,758
    agreed, i don't like replacing anything before it's time, just a waste of resources.
