2013 Prius 2 For Sale
Discussion in 'Prius Cars For Sale' started by AmazingFacts, Mar 2, 2023.
  1. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    For sale by owner is my 2013 Prius 2 for $8900. I am the second owner and have had the car since August of 2021. Selling because I'm able to work for home. I've done a complete head gasket job including new gaskets, cylinder head resurfacing (have receipt), OEM Toyota water pump and OEM Toyota bolts, and spark plugs in Sept 2021 and have put a 16000 miles on the car. I have verified that the piston rods are not bend either. The EGR was also cleaned thoroughly and should be good for another 50-100k before the next maintenance cleaning. The car runs excellent and I consistently get 55 mpg on both highway and city. The car does not burn oil either or leak coolant. This means this car is more reliable than most other generation 3 Prius' out there.
    Also I do have the Carfax from the previous original owner which shows the full maintenance of the car including synthetic oil changes every 5k miles.
    Some highlights:
    - 270k miles
    - Clean title and pink slip in hand
    - Immaculate and excellent condition overall
    - Newish tires
    - Newish 12v battery
    - No funny smells inside
    - Steering and suspension tight without any play or sounds
    - No CEL (check engine light)
    - Inside perfect with no tears on seats
    - Keyless start with 2 key fobs
    - Auto unlock from driver's side door
    - Cat shield to prevent catalytic converter theft (installed Sept 2021)
    - Viper alarm (installed in Sept 2021)
    - Dashmat to keep glare to minimum
    - No leaks anywhere
    - No funny knocks or sounds upon startup.
    - Head gasket job done properly (have pictures upon request). No K-seal (or similar) temp fix used. Used OEM Toyota cylinder head bolts and seals
    - Water pump and thermostat replaced with OEM Toyota parts
    - New coolant (OEM Toyota)
    - EGR system thoroughly cleaned and maintained
    - Transmission fluid change done 2000 miles ago
    - Excellent MPG, 50 consistently both city and freeway (70 mph)
    - Rarely driven past 72 mph on freeway
    - Drives super smooth and no vibrations on freeway
    - No rust anywhere
    - Adult owned
    - All stock
    - All maintenance is up to date including synthetic oil change 500 miles ago
    - No issues with hybrid battery
    - Drives like new
    - Couple very small dings
    - Original paint perfect and no fading anywhere
    - Always parked in shade/carport
    - No accidents
    - No smoking
    - Everything works from heater, AC, windows, door locks, all lights, EV mode, radio, USB/MP3 connect to phone, etc, etc
    - Headliner and carpet very clean with no major stains
    - Registration good until August 2023
    - Fresh synthetic oil change at 270k (2/28/2023)
    - Trailer hitch (wasn't used for heavy towing but rather for cargo carrier)
    Car has high highway miles but should be good for at least another 250k miles considering a properly done head gasket job, full maintenance, and have tested over 12000 miles since. Also keep in mind Prius taxis get 500k+ miles easily. I do drive the car every week so hybrid battery is in good shape as well.
    Serious buyers only please. Please leave phone number and I will call back asap.
    Car is located in Madera, but I travel to San Jose often and can show there as well.
    Will smog for buyer.
    Thanks for your interest.
    #1 AmazingFacts, Mar 2, 2023
  2. gramps
    gramps Member
    200
    45
    Southeast Texas
    I'm not seeing the mileage, how many miles on it?
  3. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Whoops sorry. Just added it in. It has just over 270k miles.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    Wow. There might be big money at the end of the rainbow for those of with elderly Prii!
  5. JerryCS
    JerryCS Prius camper with trailer hitch
    77
    Elk Rapids, MI
    Still available? Sending my phone by pm.
  6. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Yes still available.
  7. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Do you still have this?
  8. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Yes still available. Has almost 273k miles on it now. I've also added a back up camera on the oem factory screen which works great.
  9. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Lowering price to $8400. I still drive it couple times a week and everything works great. Always parked in the carport/shade. OCC has been drained couple times between oil changes and usually OCC is about 1/4 filled.
  10. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Pending sale...
  11. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Sold
