2013 Prius C 2- Base Radio Problems
Discussion in 'Prius c Audio and Electronics' started by Celliott1778, Mar 3, 2017.
  1. Celliott1778
    Celliott1778 Junior Member
    Hampton Roads, VA
    I recently bought this used from a Toyota dealer and the radio has been a huge issue. First was issues with Bluetooth connectivity and the dealer eventually replaced. Today, I get in the car this morning and the radio won't do anything, it lights up, shows it ok 87.9 FM, which is dead air in my area, and then none of the buttons work...can't switch to Bluetooth, can't even change the dial or volume! I turned car off and on, same issue. I am about done with this system, wanted to keep so I could keep factory Bluetooth mic, but I am ready to throw in the towel. Anyone else have any issues like this or suggestions? Thank you
  2. Gasoholic
    Gasoholic Junior Member
    35
    Bakersfield, Ca
    2016 Prius c
    How recently, was there an implied warranty period for the car? If really recently, weeks, I would approach the dealership for help, they may do some sort of good will repair.
    Gasoholic
  3. Celliott1778
    Hampton Roads, VA
    There is a 3 month/3k mile warranty on power train. Dealer relaxed the first radio and didn't have to, but I think their radios aren't good. He said Toyota makes great cars, but stereos have issues. His wife, a friend of mine, has similar issues in a RAV4.
  4. Christophers
    Christophers Active Member
    269
    104
    Honolulu
    2015 Prius c
    I'm currently having issues with me navigation. Hopefully Toyota will fix it.
  5. Philip from Canada
    Philip from Canada Junior Member
    2014 Prius c
    The base radio is kind of funky from the star , upgrade to a touch screen , designed to work with the car , plug-and-play , save you the customs installation bill too.
  6. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Man I wish that I hadn't read this thread. No problems until 10 minutes after reading. Bluetooth dropping constantly. Swung by the dealership and talked to my friend back in the shop. No update for a Prius C. 2 radio (base) but there is one for the "Entune" version. He's going to look at it sometime this week. I'll post if anything was found. (Note: Only having Bluetooth connectivity issues, none of the other problems you mentioned)
    *edit: should add I realize this thread is a bit old, but maybe the info can help someone else if they are having issues*
