2013 prius C electric issue
Discussion in 'Prius c Main Forum' started by tonytang, Oct 27, 2025.
  1. tonytang
    tonytang New Member
    Saint John, nb
    bought a used 2013 Prius C, not sure if it is one or two, 400K km milage.i have driven it a few days everything seems works perfectly until I got it replaced the front brake pads and right side front wheel bearing. I didn't do the job, my neighbour which is a 20+ years mechanic running a garage did the job. on the way back from the garage, I noticed some lights popped up, and speed reading started going crazy, especially when I was padding brake, it would go from 50 to 5 then 12 or anything but not the true speed. 10-20 minutes later, it showed up check hybrid system, engine oil pressure low, all the lights on the dash lights up, including, parking lights, abs, engine light, electric power steering light, slip indicator lights, brake warning light and more. So, I pulled over to the curb, and called the tow service. during the waiting, I checked the engine oil level, it is good (changed 5 days ago), coolant level and temperature, coolant is full, and at the coolant cover it is warm, not even hot. and I found two weird problem, 1 was if I pad a few times of brake, the car will turn off, just like loose power connection, the 2nd is, even if I turned off the vehicle and pulled out the key, the immobile lights keeps blinking, and something keeps clicking once the immobile lights blink.
    vehicle towed back to garage, neighbour checked everything like I did, engine oil good, coolant not overheat, OBDII read tons of error codes: p0117, low input of engine coolant temperature circuit , p0441, incorrect purge flow of evaporative emission control, P2420, evaporative emission pressure switching valve is stuck in off position, U0129, lost communication with brake system control module, c1380 malfunction of stop light relay, c1467 circuit of left rear speed sensor, U0074 communication bus of control module is off, U0124, communication with lateral acceleration sensor module is lost, U0126 communication with steering angle sensor module is lost, U0293, communication with hybrid vehicle control system is lost, U0293, lost communication with HV/EV ECU, U0101 communication with TCM is lost, U0142 communication with body control module B is lost, U0155 communication with instrument panel cluster (IPC ) control module is lost, U0100 lost communication with ECM/PCM/EV"A", U0151 lost communication with restraints control module, U0164 lost communication with HVAC control module. he is a good mechanic , but he had limited exprience with hybrid prius. and we dont understand why would this happen.
    anyone can help me on anything I should check step by step?
    appreciate
  2. tonytang
    tonytang New Member
    Saint John, nb
    when the tow truck came, I drove onto the tow truck, and the hybrid battery was working, I drove on by hybrid battery ( engine was not humming)
  3. John in Vermont
    John in Vermont Junior Member
    50
    Rochester, Vermont
    2018 Prius c
    When everything goes sideways at once I would be suspicious that your 12 volt battery has started to fail which will cause just about every piece of electronics in the car to start to throw error codes.
    52,713
    get a free load test at most auto parts stores
  5. tonytang
    tonytang New Member
    Saint John, nb
    what is load test?
  6. BiomedO1
    BiomedO1 Senior Member
    4,458
    2,349
    Left Coast
    Your mechanic should know - It's a test of the battery's capacity.
    FWIW; A Prius will stump even a good mechanic, unless they keep up with current technology and the latest diagnostic tricks. He may be able to fix an old broken tractor, but a car with multiple ECUs onboard may be another story.
  7. Leadfoot J. McCoalroller
    8,247
    7,752
    Pennsylvania
    2018 Prius c
    There may be more than one problem. I'm suspicious of the wheel bearing replacement- there is a wheel speed sensor integrated in those bearings, and when one of those sends junk data into the system lots of problems can occur.
    I had a situation with a poor quality (possibly even counterfeit) bearing replacement that really freaked out our car with many seemingly-unrelated errors. Swapping the bearing for a genuine Toyota item solved it instantly and permanently.
    That said, the list of problems we had wasn't as long and weird as yours, so I'm a bit suspicious that there's more going on than just a duff speed sensor- but that's where I'd start.
    BiomedO1 likes this.
  8. tonytang
    tonytang New Member
    Saint John, nb
    but he just replaced the bearing not the bearing assembly, basically, only push out the old bearing and press the new bearing in. we did suspect the abs speed sensor as the culprit, so we disconnected it and ran the vehicle, but nothing solved, all the problems stayed, except a new error code coming up stating lost connection of the abs sensor.
  9. tonytang
    tonytang New Member
    Saint John, nb
    I totally agree, but it is kind of too late.
  10. tonytang
    tonytang New Member
    Saint John, nb
    yep, a lot of people believe the 12V battery may affect those control units, so did my mechanic neighbour, I have showed him there were 14.1V from alternator, it didn't matter if the 12V battery work or not, however, I still purchased a brand new S34b20R and installed it on, after cleaning all the codes, 5 minutes later, more codes coming back, speed reading still showing crazy, when it is running 50, it showed 3, 14 or whatever number but not 50, every lights still on, hybrid battery still showed ready but check hybrid system, after changing the battery, nothing really change.
  11. tonytang
    tonytang New Member
    Saint John, nb
    wasting $400 + though
  12. ChapmanF
    18,900
    A lot of trouble codes. Look them up in the repair manual and start following the troubleshooting steps for them.
    Toyota Service Information and Where To Find It | PriusChat
    I would start with the U codes, which are all communication problems between modules. Your meter can't display the right speed, for example, if it can't get that number from the brake module (which is the one the wheel speed sensors connect to). You have to get all the communication problems sorted before tackling much else.
    Despite the intimidating number of codes, as you follow through the troubleshooting steps, you may be led to one obvious spot of wiring damage or the like that accounts for most or all of them.
    tonytang and BiomedO1 like this.
  13. BiomedO1
    4,458
    2,349
    Left Coast
    I beg to differ; your wallet is $400 geese lighter.:(o_O That's why we suggest TESTING rather than pointing a "parts cannon" at problems.
    Seriously; all your problems started with that repair - so that repair is highly suspect. The other option is that rodents started chewing on your wiring harness while the car was out of commission.
    Something is throwing a lot of 'noise' into your CAN bus disrupting the ECUs ability to communicate with each other - therefore all the unrelated error codes and funky actions of your speedometer. This is acting like a car that's been underwater, creating a bunch of ground bridges, so all your electronics are 'wigging-out'.
    I would start by inspecting the wiring harness for shorts and chew marks; especially around the repair area. Source a used wheel hub assembly with either a new or used sensor and replace the one that was just repaired to rule it out. Don't know how those wheel sensors are wired together or report to a common point - you'll need to consult with the car's wiring diagram. Seems strange that your rear left wheel sensor kicked an error code - you may want to look there too. Sometimes those wires gets snagged onto some road debris and get ripped out and shorted together.
    Good Luck.....
    I once had an apprentice broke a couple of teeth off of a half shaft replacement and didn't say anything. Took the car for a test drive, before handing it back to the customer, only to find a bunch or ABS/Traction control error codes popping up. We called it a defective replacement half-shaft and had to keep the car for another day....... The shop's reputation would've took a big hit; if that slipped by our QC - Needless to say; an apprentice that's too liberal with a hammer isn't going to last and would eventually start costing the shop time and money.
  14. tonytang
    tonytang New Member
    Saint John, nb
    I mentioned the funky actions of the speedometer because while I was driving home, I noticed the speed showing was getting weird, then some warning lights popped, couple miles later, the checking hybrid warning jumped up then the low engine oil pressure warning. it all started with the funky actions of the speedometer, I dont know if they are related, but that was the sequence it happened.
  15. Leadfoot J. McCoalroller
    8,247
    7,752
    Pennsylvania
    2018 Prius c
    That's exactly why I'm suspicious of the wheel bearing.
    The speedometer derives its data from the outputs of the four wheel speed sensors. That data gets used for lots of other things.
    If one sensor is suddenly blasting junk data into the network, and one of the computers in the middle is struggling to make sense of it/getting overloaded/crashing then you can get all kinds of seemingly-unrelated symptoms.
    Even if it is truly coincidental and the wheel speed sensor is fine, something is causing network disconnects and failed responses within the network in that car.
  16. ChapmanF
    18,900
    I'm not sure I'd suspect a wheel sensor of such widely pernicious effects. It's not as if each wheel sensor is a CAN node able to jabber on the network. They're just dumb transducers delivering a train of regular pulses back to the skid ECU, with the pulse train frequency proportional to speed.
    The skid ECU is what observes those pulse frequencies from all four wheels and computes how fast the car is going. Then it can communicate that info to other modules in the car, like the combination meter, that ask for it.
    Problems with a wheel speed sensor might be a signal too faint, or missing pulses, or shorted to supply or ground (maybe intermittently). Those will make the skid ECU set wheel sensor trouble codes, but by themselves I can't picture them causing network communication problems.
  17. Leadfoot J. McCoalroller
    8,247
    7,752
    Pennsylvania
    2018 Prius c
    I admit it seems like a lot out of one sensor, but the original complaint stated that the problem started occurring on the ride home from the garage where that bearing replacement was done.
    Not a smoking gun, there are such things as coincidences, but it struck me as worthy of a recheck anyway.
  18. Danno5060
    Danno5060 Active Member
    397
    206
    Wyoming
    Admittedly, the first thing I'd look at was the repair that started the whole mess. However, most of the problems don't seem to be from a bearing replacement. I'd want to see if those are current codes or history codes.
    I'd probably start with the communication codes. To me, this seems like the problem that's causing all the other problems. There is a network of ECUs that all have to talk together to make the car run right, and if these ECUs can't communicate properly, you'll get a bunch of strange codes from all over the place. Mainly because the data being communicated between the various computers is either missing, intermittent, or stale.
    I can't seem to find a good example, but the guy from South Main Auto on YouTube, and also the guy from The Car Care Nut, have some pretty good videos on how they solve communication problems.
    #18 Danno5060, Nov 5, 2025
  19. tonytang
    tonytang New Member
    Saint John, nb
    thank for the suggestion, I started to remember, after I purchased it, once when I was driving, it flashed some lights for a couple seconds, then disappeared, i thought it might be something malfunction. it could be the start of some wire harness connection issues, and I guess replace the bearing worsen the connection. history codes are all cleaned, these are permanent codes.
  20. Danno5060
    397
    206
    Wyoming
    I think this is the sort of thing that may help. It's not a stellar example, I've seen more poignant videos, but this is still to the point.
    There's at least one communication bus running through the ECUs. This is a pair of wires that get a push/pull (one wire goes positive, one goes negative at the same time and it's the difference in voltage that is used by the ECUs to send (or receive) the messages. The diagnostic port (OBD2 port) sits in the middle of the bus. The ECUs at the end of the bus have a resistor that simulates an infinite extension of the pair of wires to absorb the signal reflections that would happen if the wire impedance didn't match. One of the things yuo can do is to figure out which two wires on the OBD2 port are used for the communication bus and measure the resistance. If the bus is disconnected between the port and the end on one side, you'll get twice the resistance you should (resistors in parallel). I forgot what this figure is. (That's the kind of video I've been looking for. The car care nut had what I was looking for here, but I can't find it.)
    Another problem is if some of the ECUs have blown fuses. That makes them not able to talk to the other ECUs, tripping codes in the other ECUs. The video highlighted another problem where the ECUs are powered, but not actually turned on until the vehicle's ignition is active.
    What the video did show is how the entire dashboard lit up with alarms, mainly from all the ECUs not communicating, like the tire pressure alarm being set, not from a tire pressure actually being low.
    His diagnostic process is valid. He picks an ECU that doesn't talk (either to his scan tool, or to the other ECUS) - the one that's easiest to get to. Then figure out why it isn't talking (power to the ECU, communication wires...)
    Keep us informed as to what you've found when you get this solved. I may be full of crap, I'm just shooting in the dark here.
