2013 Prius C Engine vs Head Gasket Replacement
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by J.Masters, Dec 29, 2021.
  1. J.Masters
    J.Masters New Member
    Camden, AR
    Car Information:
    - 2013 Prius C One
    - Original Owner = Me
    - Mileage= ~ 203K
    Current State:
    • A few weeks ago had a really violent start-up. (white smoke coming out of the exhaust and sounded like the engine was choking out).
    • The next day, noticed a few drops under the car = Loose clamp(fixed it) and the overflow reservoir was at “low”(filled it)
    • Last week check the overflow reservoir and it was half full(filled it)
    • Currently, losing about 1/8th of the reservoir a day with zero leaks.
    Conclusion: Head Gasket has a small leak path...
    Question:
    1. Engine vs head gasket replacement(Labor Cost is the same)?
    2. Where can I get a reliable used engine?
    Background:
    • Overheat Light Came On While Driving(Drove another 10 Miles home after light Came on)
    • Checked after stopping (Zero Coolant in Overflow Reservoir and leak in Hose found)
    • Replaced Fluid, changed hose, and replaced the thermostat(shotgun replacement)
    • Two weeks went by overheat light came on again = Temp sensor (error Code) and overflow reservoir was full.
    • Replaced Temp Sensor water pump(Shotgun Replacement)
    • One week passed by and the overheat light came on again. = Fan Not running and noticed coolant on the ICE located at a seam)
    • Replaced Fan and cleaned seam to see if fluid would return. (it has not)
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Engine replace, those engines are reliable compared to regular prius
    J.Masters likes this.
  3. Sonic_TH
    Sonic_TH Active Member
    525
    83
    Puerto Rico
    Well, now you know, if the overheat light comes on, turn the car off immediately.
  4. J.Masters
    Camden, AR
    Yeah, rookie mistake for sure
  5. J.Masters
    Camden, AR
    Ordered and on the way to the dealership.
    $3K USD Labor
    $809 USD Engine
  6. J.Masters
    Camden, AR
    In my opinion, after 170,000 Replacing the temp sensor, thermostat, and water pump for no other reason than "planned obsolescence". Curious as to why Toyota doesn't have this as part of their maintenance timeline rather than allowing these parts to run to failure before replacement?
  7. Sonic_TH
    525
    83
    Puerto Rico
    The thing that failed was the thermostat or the engine water pump? If you already replaced these as preventative maintenance, it's weird that one of the 2 failed so soon.
  8. J.Masters
    Camden, AR
    Replaced thermostat, water pump, temp sensor and fan. It was strange that they all failed.
  9. Sonic_TH
    525
    83
    Puerto Rico
    Did you bleed out the air correctly after adding coolant? and what coolant did you use?
