2013 Prius C leaking at rear seat belt roof assembly
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by horstuff, Jan 6, 2021.
  1. horstuff
    horstuff New Member
    Northern Oregon Coast
    It has been leaking for a few weeks, I finally tracked down where it's coming from, see pics... the seat belt trim at the roof is sopping wet, and the water runs down each side of the roof liner as well. But a piece of cardboard there during the last rain shows that the water is dripping right down from that seat belt trim. Is it one of the two seals shown in a photo here, like the wiper wires or the brake wire?
  2. horstuff
    horstuff New Member
    Or maybe it's this, see antenna pic... I just noticed that one side of the seal is lifted a bit (left rear in picture) but the headliner underneath it down to that seat belt thing doesn't seem wet.
    48,996
    not sure about the c, some liftbacks have cracks in the rain gutter, under the black trim
  4. Leadfoot J. McCoalroller
    6,843
    6,484
    Pennsylvania
    2018 Prius c
    Any leaves or garbage caught in the rear door jamb area? If that can't drain out, water will find a way through the wiring grommet for the stop lamp.
  5. horstuff
    horstuff New Member
    Thanks for the responses. It was the antenna seal. I ordered a shark fin from the PriusChat store which will be here in two weeks, it goes over the existing so it'll be an all new seal. In meantime, I used a bit of marine calking to keep the water out until I mount the new antenna. Thanks again all.
  6. Leadfoot J. McCoalroller
    6,843
    6,484
    Pennsylvania
    2018 Prius c
    Mmm... good luck with that!
  7. horstuff
    horstuff New Member
    Have you heard bad things about those?
  8. Leadfoot J. McCoalroller
    6,843
    6,484
    Pennsylvania
    2018 Prius c
    I know nothing specific about the part. It's the store. Lots of fulfillment issues.
    My own personal experience was okay- I bought some accessories and got my stuff just fine, but these pages are full of stories of less positive moments.
  9. horstuff
    horstuff New Member
    Thanks for the input. The marine caulking seems to be working and should last awhile, hopefully the part arrives before too long.
