2013 Prius C speedometer
Discussion in 'Prius c Main Forum' started by Dee2591, May 5, 2021.
  1. Dee2591
    Dee2591 New Member
    Franklin
    Hello. I'm two days from a road trip and suddenly my speedometer isn't lighting up on my dashboard. At all. everything else on the dash lights up just fine but the speedometer just disappeared. I did notice this happened after filling up my tank. My 2013 is very basic and uses a key to start. There is no button. Does anyone know an easy fix for this?
  2. dubit
    dubit Senior Member
    845
    532
    23
    Indiana
    2016 Prius c
    Obviously, you would want to check the dimmer. The switch is to the left of the steering wheel on the lower dash. (at least it is on a 2016, so I'm assuming it's there on your 2013 as well).
    Second, cycle through your displays. If none of them are showing, then the display is shorted/burned out.
    I can't see what filling up would have to do with anything so that's just a coincidence. If it is burned out, a junkyard replacement would be the cheapest. Your ODO won't be correct, but at least it would be a functional dash. Or you could do what I would do and just ignore it. lol I drove for years in a Chevrolet with no speedometer. Wasn't as hard as it may sound - just went with the flow of traffic.
  3. Dee2591
    Dee2591 New Member
    Franklin
    Dubit: Lol. and that's what I'm planning to do for now. The weird thing is the speedometer display is the only one that's out. Everything else lights up. If I don't find a reset solution, at some point I may take it in. Thanks!
Loading...
