1. diego c azuela
    diego c azuela New Member
    saipan northern mariana island
    is it possible to replace the hybrid bayttery twice and the gap inbetween is 3 years and still under warranty? my 2013 prius c got problem the hybrid battery and replace it 2016 and the millage is 26k now the millage is 60k the hybrid battery got problem again after 3 years and it says to the diagnostic need to change hybrid battery pack, the dealer told me they must asking for approval in warranty department at toyota, in my warranty booklet it the hv are 96 months and 100k miles, im just worried if the dealer decline the warranty do i need to talk to lawyer to sue them about the warranty?
  2. Leadfoot J. McCoalroller
    8,162
    7,665
    Pennsylvania
    2018 Prius c
    Two different warranties are at play here.
    The original HV battery had that 8 year/100k warranty. This was covered under the new car hybrid system warranty.
    The replacement HV battery would've had a 1-year warranty (can't remember how many miles). That's the replacement parts warranty and unfortunately it would have expired already.
    It's common for replacement parts to have shorter warranties than the originals. That's normal in the auto industry.
    Now, it's really unusual for the HV battery to fail twice in the first 8 years. Extremely unusual.
    I think your dealer has realized that this is an odd situation and they are trying to help you even though they aren't obligated.
    iceman13, diego c azuela and dig4dirt like this.
    52,497
    warranties are different in different countries
  4. Leadfoot J. McCoalroller
    8,162
    7,665
    Pennsylvania
    2018 Prius c
    Saipan has been administered by the US Government since 1945. Might not have statehood, but it's USA.
    diego c azuela and bisco like this.
  5. diego c azuela
    so do you mean if its they change the hybrid battery even though if it still covered by the warranty, so the warranty gonna done because the replacement parts is 1 year? unless if the warranty from toyota warranty card is reach already
  6. Leadfoot J. McCoalroller
    8,162
    7,665
    Pennsylvania
    2018 Prius c
    Yep, the original hybrid parts warranty only applies to the original battery, not the replacement. It still protects other parts of the car, but not the battery.
    diego c azuela likes this.
  7. PriusCamper
    PriusCamper Senior Member
    13,168
    5,326
    Pacific Northwest, USA
    When the error code says: "replace hybrid battery" it doesn't mean that literally, it means something in the pack has a problem and you have to get the sub-codes and get in their and start inspecting and testing to figure out what the specific problem is
    It's highly likely that the battery pack itself is in perfect condition, but some of the far less expensive components that makes the battery pack work properly have a problem and those parts weren't replace under the warranty. If I were you I'd be grateful for the free battery they already gave you under warranty and if there's no more free stuff you can get from them find an honest mechanic that has hybrid skills or interest in learning them and work with them to fix that problem for the lowest price possible.
    Sonic_TH likes this.
  8. Leadfoot J. McCoalroller
    8,162
    7,665
    Pennsylvania
    2018 Prius c
    Has anyone checked the battery cooling fan?
    If that fan and its air ducts aren't kept clean the car will act like it's got a wrecked battery. And it can wreck the battery for real.
    These cars expect you to use a lot of air conditioning all the time, helps keep the battery temp down.
    dubit likes this.
  9. PriusCamper
    13,168
    5,326
    Is the fan mounted to battery pack in Prius C ? You'd think the warranty replacement would of covered that?
  10. Leadfoot J. McCoalroller
    8,162
    7,665
    Pennsylvania
    2018 Prius c
    I've never removed the battery from mine, but it appears to be a briefcase-sized metal box inside the crash cage under the rear seat cushion. The fan sits to the left of it with a plastic duct to connect. I'm not sure if the fan is anchored to the battery case, the car floor or the crash cage.
    PriusCamper likes this.
