2013 Prius - correct spark plugs?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by chuckiechan, Jul 21, 2022.
  1. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    From my searches here it seems the 2013 Gen3 regular Prius uses a hotter plug? Is it hotter than the factory ones I am removing (90,000 miles)? Or was this a later update?
    I’m confused.
    It is likely Auto Zone, etc. will have updated part numbers?
    I’m planning to get Nippon Denso iridium.
  2. JC91006
    16,939
    8,647
    The OEM spark plugs are good for 150k miles. You don't have to change them at 90k.
    But to answer your question, there is a hotter plug available, some use it, some don't.
    52,904
    wait for 120k as the schedule provides, and get them from a dealer to avoid serious problems with counterfeits
  4. Mendel Leisk
    42,379
    Page 562 of the Owner's Manual spec's the plugs:
    Except: Toyota has revised the plug, it's now SC16HR11, slightly hotter. Simple as dirt way: call dealership parts department, tell them you need plugs for a 2013 Prius, see what they come up with. Just in case there's been another revision, which they "should" be on top of.
    Torque spec (from Repair Manual) is 15 foot/pounds, presumably with clean/dry threads. You need a 14 mm or 9/16" spark plug socket.
  5. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Got it! Thank you.
  6. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    I got Denso IL16TT.
    he said that’s what to use. Am I good to go?
  7. CR94
    CR94 Senior Member
    2,840
    1,246
    Northwestern S.C.
    I just bought SC16HR11 for $8.95 apiece from McGeorge Toyota.
    Foxglove and chuckiechan like this.
  8. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Dummy gave me the wrong plugs. Returned them went to Napa and installed the same number as I took out.
