2013 Prius engine not shutting off at stop
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by randommonks, Jul 4, 2016.
  1. randommonks
    randommonks Member
    65
    37
    Houston, TX
    So it's an issue I've noticed 3 times now this summer. The car has been driven for at least 5 minutes each time and should be past the warm up phase. If I'm sitting at a light, the gas engine just keeps running. I thought it might be some kind of computer error so I tried powering the car off and turned it back on. EV mode will stay on for about 30 seconds but then the gas engine turns on again. Battery is 3/4 full like normal with the AC on. I've tried putting the car in EV mode but it says "not available". Temps in Houston have been in the high 90's recently so I'm wondering if this is the result of an overheated battery or if it's something I need to be worried about and take in to the dealership?
    Car currently has around 34,500 miles and I've had the car since it had 79 miles. All oil changes done on time at my local Toyota dealership. 12V battery is original to the car.
  2. Mendel Leisk
    42,361
    How about after 15~20 minutes run time, does it then shut down ok? I'd put it down to vagaries of the warm-up phases.
    I do notice with partially warmed engine I can get it to turn on/off, by raising/lowering the cabin temp setting. Some parameter like that at play?
  3. randommonks
    randommonks Member
    65
    37
    Houston, TX
    Actually yes after about 15ish minutes, the engine will shut off like normal. I have the AC set to around 78-82 depending on how hot it is outside.
  4. working1
    working1 Active Member
    121
    112
    Symptoms the 12V battery needs to be replaced. ICE will keep running in an attempt to charge a bad 12V battery.
  5. DongFeng
    DongFeng New Member
    Seattle
    I do not think so. The engine is working to ensure sufficient current for the air conditioning. If you switch off the air conditioner, does the engine stop running?
  6. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I don't think so, once in Ready Mode, there is plenty of voltage/current from the traction battery.
  7. randommonks
    randommonks Member
    65
    37
    Houston, TX
    If I notice it happening again, I'll try turning the AC completely off. I can check the battery level when I'm at work tomorrow as well.
  8. bisco
    52,877
    maybe it just hasn't completed the warm up cycle.
  9. xliderider
    8,140
    3,280
    Honolulu, HI
    +1, I agree. OP stated only 5 minutes into drive in first post.
  10. bisco
    52,877
    i have always found the prius warmup pretty inconsistent. hard to figure sometimes.
  11. randommonks
    randommonks Member
    65
    37
    Houston, TX
    Hm well it seems like an unusually long warm up then in the heat of summer. I've never had a warm up this time of year last longer than the first stoplight (usually around 2 minutes into the drive).
  12. bisco
    52,877
    is the battery all green when it happens?
  13. randommonks
    randommonks Member
    65
    37
    Houston, TX
    Battery is always at normal charge level (3/4 of the way full) when this happens. Edit: I think once it was 7/8 full.
  14. xliderider
    8,140
    3,280
    Honolulu, HI
    2 minutes into the drive, are you serious? It takes longer than 2 minutes to raise the engine coolant temp. Plus, you stated the engine does shutdown normally after a much longer period has elapsed.
    You're worrying about nothing IMHO.
  15. randommonks
    randommonks Member
    65
    37
    Houston, TX
    Just stating my experience with my car (that I've had for almost 3 years). How long does yours take before the engine will shut off?
  16. Mendel Leisk
    42,361
    On warm days I can get engine shutdown at the end of the first block. But that's after using the block heater for a couple of hours. :whistle:
    randommonks likes this.
  17. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    If it has been sitting in the heat for hours, the engine may be running to keep the battery temp down. I've found that my AC will blast if the car has been sitting in the heat, even up to 10 amps for the compressor alone. I have the temp set to 79 or 80 so I think this is intended to cool the battery rather than me. When it does this the battery temp is usually at least 105 F. If the AC will blast like that, the engine may run if the battery is even hotter so that it doesn't get hotter still trying to move the car. Just a guess.
    xliderider and randommonks like this.
  18. randommonks
    randommonks Member
    65
    37
    Houston, TX
    That's actually similar to what I suspect since I've only noticed in the afternoons.
