2013 Prius error code 303.. cylinder 3 misfire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ACandela, Aug 4, 2018.
  1. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    Hello...
    I'm new to PriusChat.
    My 2013 Prius went in for maintenance yesterday. There's been a ongoing "engine light" error issue
    and "cooling fan" error that has been consistent for the past year.
    My mechanic (who owns his own 5 star rated shop specializing in Toyota/Lexus and used to work at a Toyota dealership) checked both codes. The "cooling fan" error was first resolved by cleaning the blower fan in the back seat and the cooling fan error still came on. My mechanic says that the fan is running fine.
    The"engine light" error came up that the car was possibly running lean. It was discussed to possibly replace the AF sensor. Also the MAF sensor had been cleaned and the "engine light" still came back. He ran tests and could not directly find what was causing the engine light issue to continually come back.
    So I received some difficult news yesterday while he was doing my routine oil change and maintenance.
    An additional engine error code showed up (along with the same lean code) and this one was a "cylinder 3 misfire". Without delving deeper into the issue he was saying basically this could be a head gasket and/or cylinder/engine job which could run into thousands of dollars! My mechanic said for now to watch the engine coolant level. If it starts dropping to mark the levels. He feels that if coolant is leaking into the 3rd cylinder this could be the cause of the misfire. He said if that's the case it would still involve checking the head gasket, engine, cylinder, etc.. very costly.
    To give you a background on the 2013 Prius, I'm the 2nd owner and purchased it Dec.2015 from a Toyota dealer with about 72K miles on it. It's my only car and have been using it primarily to UBER/LYFT.
    I'm aware that the value of the car would shoot down with higher mileage.. are you ready for the miles..?
    approximately 218K miles. Alright, I know I can hear many of you saying are you nuts, etc..?
    Well, I still have $10K left before the car is paid off and I'm certain the Prius value is a few thousand less than my pay off amount.
    My dilemma is... I'm pretty much done doing the ride share because of the car's mileage and how much I've driven. With this 303 cylinder misfire code and how much would be needed to possibly fix this issue it seems that it may not be worth holding on to the Prius. :(
    With the exception of a few minor cosmetic dings/scratches.. this Prius Persona package can be rated as very good to excellent condition.
    I'm here to get experienced feedback if anyone has/is going through a similar situation.
    Appreciate any thoughts about this. ~A~
    amos likes this.
    52,891
    welcome!
    sorry for your troubles. has the mechanic cleaned the egr circuit an intake manifold?
    Raytheeagle likes this.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    I would try to swap the cylinder spark plugs first, erase the code and see if it comes back, if it does, swap the ignition coils out and do the same thing. If it still comes back, do a compression testing on the cylinder.
    Also, do all of the maintenance for your vehicle since it’s a high mileage vehicle. All of the videos can be found on our YouTube.
    And the 2013 Prius aren’t known for head gasket issues, so I would do all of the easy stuff first before opting to sell the vehicle or giving up on it. GL
    danlatu and Raytheeagle like this.
  4. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Not sure where you’ve been, but headgasket issues are becoming quite common on all of the 10-15 Prius with the 2ZR-FXE. If you belong to any of the professional groups such as iATN, there are discussions about this on a regular basis. There is even discussion about this amongst the various technician groups on Facebook. Anything with around 150k+ is a potential candidate, and cyl 2-3 are usually where the failure occurs.
  5. NutzAboutBolts
    1,756
    1,789
    Bay Area
    I’ve only been on here. Good to know there’s more places discussing about this issues. I will keep my eyes open for the 2012-2015 head gasket issues.
  6. NutzAboutBolts
    1,756
    1,789
    Bay Area
    @The Critic what are the Facebook group page you were referring to?
  7. The Critic
    3,193
    2,333
    CA
    There’s a group for professional auto techs.
  8. NutzAboutBolts
    1,756
    1,789
    Bay Area
    Is it the group with 6.3k members?
  9. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    Hello Bisco...
    The mechanic and I haven't delved into the "troubleshooting" aspect yet.
    There seems to be many variables related to the P300 error code.
    For now, he want me to watch the coolant level and see if there's a significant drop.
    With the current So.Cal. heat wave, I've been using the AC more and the coolant has been dropping. But I'm attributing this to
    the amount of energy the Prius is pulling with my ride share miles and the heat.
    I may hold off until Sept. for my next maintenance check up and have him start troubleshooting from there.
    Honestly... if it ends up being in the $$$'s of dollars I may have to let go of this purple beauty.
    And I'm trying not to add tons of more mileage to the Prius.
    amos and bisco like this.
  10. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    Thank you NutzAboutBolts!
    I have no place to do the oil change at home. The car rests on a driveway that has a incline and with a problematic issue with error
    codes I might as well just have the mechanic service it. I obviously put a lot of miles on the car so my wheels need to be rotated, and
    brakes checked monthly.
    I will mention your suggestions to Joe.
    It had major service 1 yr.ago spark plugs replaced, cabin/air filter replaced, inspect steering, suspension, and exhaust components, etc.
    A pretty long list of items. Mileage was 164,9432 when the Prius had the major service.
    I'm concerned about adding a lot more mileage and not knowing how serious this issue could be.
    Also would you think it could be a faulty MAF or AF sensor?
    NutzAboutBolts likes this.
  11. The Critic
    3,193
    2,333
    CA
    Yes. IATN and diag network are still better, but the Facebook one is free.
  12. NutzAboutBolts
    1,756
    1,789
    Bay Area
    Alright, I’ll keep my eyes open and see what’s going on. Thanks.
  13. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    Hello The Critic...
    I just got off the phone with one of the mechanics and he said that the EGR and Intake Manifold isn't the issue.
    They've already replaced quite a few intake manifolds relating to the "misfire code" and the the code still came back.
    He still suspects the head gasket leaking coolant into the #3 cylinder. And to work on it would be $3600-$4200.
    For now, Gary (one of the mechanics) will opt to do what nutzaboutboltz suggested.
    Swapping the spark plugs/ignition coils, clearing the error code, do a compression test, and see how it responds.
    He will want to test it out in the AM on a cold start and see of coolant is leaking to the cylinder.
    One question.. how is the coolant leaking into a certain cylinder and not the others?
  14. bisco
    52,891
    the head gasket blows in just one spot, the narrow area around a cylinder, and the coolant leaks in through thereof you're losing coolant, it is not the heat.
    ACandela likes this.
  15. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    He should run a scope inside the cylinders and see if it's clean, from water/coolant getting inside and steam cleaning
    the top of the piston.
  16. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    Got it! Thank you for your reply.
    The mechanic tells me that he will test/swap out the ignition coils and spark plugs and run a cylinder compression test.
    About $160.
    I'm a bit tight this month, but until I get the car in the shop (later in the month) I'll watch the coolant levels and add water to the coolant if needed.
  17. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    I think he'll be doing similar.. possibly using a scope.
    I'm bringing the Prius to the shop later this week to check the engine light code and see if it's still showing the "engine misfire"code.
    It probably will, but having 200K+ miles anything can happen.
  18. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    If I were in your shoes, I’d start looking for an engine. Before everyone crucifies me, this is why. When I bought my Prius in March, it had a mystery coolant leak. It was leaving the reservoir, but not making it to the ground. I added Blue Devil Pour and Go sealer to it. The disappearing coolant stopped. 3500 miles later, the engine failed in dramatic fashion. The picture of the Number 1 piston is on my profile. If you are leaking coolant at the head gasket, it’s a ticking bomb. When it fails altogether, it will be sudden, and the engine will fail in dramatic fashion. The failure of my engine showed the ICE was off, cylinder 1 filled with coolant, then the ICE attempted to start up. Coolant does not compress. Broken piston, bent rod, and huge holes in the block is how mine turned out.
    My feeling, and personal experience is replacing engine with a running engine is less labor, and less expense then repairing your existing one.
  19. ASRDogman
    8,070
    4,092
    Makes sense. OR replace the head gasket before it causes a disaster...
    RMB likes this.
  20. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    Thank you
    Thank you for the reply, CNC97,
    I'll be returning to my mechanic today as the engine check light is on and we want to make sure nothing else is showing up.
    My odometer is at 219,000+ and I'm now averaging about 36mpg. I'm guessing with one cylinder misfiring that I could be getting the poor gas mileage. I average about 68-70mph while on the freeway. Again all the UBER/LYFT miles has racked up and now I'm facing a BIG decision.
    I'm still making payments on this car with about $10K remaining. Honestly, I can't afford a major overhaul on a car.
    I was already quoted about $4K for the head gasket/cylinder job. New engine.. I can't even imagine!
    I'll follow up on this thread after I speak with the mechanic today. Pins and needles right now!
    amos and Raytheeagle like this.
