2013 Prius error code 303.. cylinder 3 misfire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ACandela, Aug 4, 2018.
  1. amos
    amos Active Member
    376
    285
    los angeles
    Well find the time and take it for a pure fwy drive at night. No a/c. You still need to do something bout your hg soon
  2. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    Left a message for "danlatu". Will play everything by ear. I'm giving myself until late Sept. to take care of this matter.
    Thank you for the replies/support. It does mean a lot! :)
    And yes, I take care of the cars I've owned. It's a investment that I have to protect the best way possible.
    amos likes this.
  3. amos
    amos Active Member
    376
    285
    los angeles
    Well its really not my business but i would think 10 times each time i turn it on. That crancking noise i hade was too much. I also had it when sometimes i made a left turn on red right in the middle of intersection.
  4. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    This (the HG) I know. Once I take the car in Sept. for it's maintenance, I'll decide then.
    See if I can work out something with my mechanic, if not then I may consider going to Prius Express, etc.
    The CASH ONLY is the caveat for me.
    amos likes this.
  5. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    There's no obvious idle or difficult start up. Maybe a slight sound, but nothing that is disturbing. Catching the HG in it's early stages.
  6. amos
    amos Active Member
    376
    285
    los angeles
    Who said its a cash place. Try not to drive it. Not a smart move
  7. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    You did!
    Trying to limit my driving.
    By the way, I called my mechanic and it sounds like for a HG job they send the head out to be resurfaced and checked, basically
    a HG rebuild. That and to check the cylinders he quoted me $3600.
    Another referred mechanic said that if the HG work was to be done it could potentially lose compression causing the engine to burn oil
    and cause damage to the pistons.
    I throw my arms up in the air at this point!
  8. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Things I know from my engine tear down. The head gasket set runs about 160. The main head bolts run about 90 from Toyota or 55 if you can find aftermarket. The cam bridge bolts run about 30. The oil and filter run about 40(depending on brand). The antifreeze is about 20 a gallon(buy 2 to be safe) Spark plugs are 7-14 a piece, depending on brand. So at 800 to do the job, either this guys time isn’t worth anything to him, or he knows a shortcut or three to get the job done.
    I'm looking at a local Prius that has antifreeze in the oil. I’ve been asked by the owner to shoot them a price. I’m not sure I’m willing to tackle the job again.
    amos and Raytheeagle like this.
  9. ASRDogman
    ASRDogman Senior Member
    7,989
    4,055
    I think it's time to learn how to do it yourself.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    I always establish a baseline for comparison ;).
    I check our cars oil level and 12 volt battery voltage every Saturday morning after they have sat overnight. It’s now a routine I have maintained for years and takes all of 5 minutes since I’ve added an oil catch can check to the docket:).
    If you have a fear or incling of a head gasket failure, I’d keep a similar check on the engine coolant too;).
    Hope that helps(y).
    amos likes this.
  11. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    3600$ for a head gasket, not worth it. Go pick this engine up in north hollywood. Running lean will destroy an engine, too much heat will kill main/rod bearings and fry rings because oil breaks down from heat.
    2010-2015 TOYOTA PRIUS V HYBRID, JAPANESE ENGINE 2ZR-FXE, 1.8L/JDM | eBay
  12. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    Well, I have to say that the $800 quote comes across like a quick fix for the HG issue.
    Then being told that the HG repair could lead to a engine compression issue and possibly cause oil to burn?
    Somehow, the general "mechanics" consensus gives me the impression that the HG could lead to engine issues down the road.
    With 220K miles on my Prius this car's longevity won't be forever. The repairs/engine replacement, etc.. are costly than average consumer vehicles.
    I'm not in a financial and work position to spend $1000's on major vehicle repairs or a new/used engine.
    Looking at the crossroad and seeing what road to take.
  13. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Used engines are available for 800 and up. Labor to put it in around 600, unless you do it yourself. Fluids and incidentals figure 150.
    amos likes this.
  14. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    Time and skills are the main factor. Honestly, messing with a "computer car" is something I will leave to the pros.
    Also, I don't have another vehicle to drive with and being based in the mountains you will need wheels.
  15. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    I've been checking the coolant level first thing in the AM before I drive.
    It's been remaining with minimal/no drop in the coolant level.
  16. ACandela
    ACandela New Member
    26
    17
    Lake Arrowhead
    If I had the extra money, I'd fly out out to have you do the job. :)
  17. amos
    amos Active Member
    376
    285
    los angeles
    My car drives great and not really burning any oil. 3600 is too much. If a mechanic talks to me like that i'd stay away. Im just optimistic bout toyota engines and rhe fact you changing oil every month. The possibility that engine is no good is always there theoretically. I would change the hg. Worth the try but not 3600. Maybe 1500 or less.
  18. amos
    amos Active Member
    376
    285
    los angeles
    Theres another place you can try.
    310-4268432 his name is avi its by western x exposition. This is an honest mechanic
    I forgot the name of the shop but its behind the 76 gas station. I cant write too much bout him but i owe him a lot for his honesty that one time dealer ruined my car computer and asked me for $4000 to repair it. Avi fixed it for nothing. It was all the dealers mess. Try him.
    Raytheeagle likes this.
  19. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    amos likes this.
  20. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    I lost count of how many head gaskets I've changed. I have yet to see one fail a second time. Good luck with the $800 job. I have never changed a head gasket without changing the water pump as well, which I doubt is included for $800.00. Who's fault is it going to be when the old water pump fails and takes the new head gasket with it?
    amos likes this.
